RAM usage
andrew-yu
RAM usage
Post by andrew-yu »
Zoneminder 1.36.7
64Gb RAM. 13 cams with Modect: 1 3MP, 11 2MP, 1 1MP. 3 cams with Mocord: 1 3MP, 2 2MP. All my RAM is in use by ZMC processes. 3 of them use 19GB, 10,6GB and 10,8GB. Other use less. Is it ok for 1.36?
Re: RAM usage
Could be.
What are the frame rates and how many cores do you have?
andrew-yu
Re: RAM usage
Post by andrew-yu »
25 fps.
14-cores Xeon CPU.
Re: RAM usage
Yeah, then that's about right.
You probably don't need that high frame rate, suggest 10 or even 6 will do for surveillance.
andrew-yu
Re: RAM usage
Post by andrew-yu »
12Gb used by ZMCs after 10 min past of system was rebooted. Memory leak?
Re: RAM usage
Upgrade to .8, might help.
andrew-yu
Re: RAM usage
Post by andrew-yu »
Upgraded to 1.36.8. Nothing changed. :(
