Looking for some guidance in getting face detection working. I believe I have set up the ml_sequence correctly but it never gets to the face detection part:
Oct 03 2021 10:47:23.246741 [DBG 1] Skipping face as it was overridden in ml_overrides
Not sure what that means, i can;t find that variable anywhere.
Here is my sequence:
[ml]
# if enabled, will not grab exclusive locks before running inferencing
# locking seems to cause issues on some unique file systems
disable_locks = no
use_sequence = yes
stream_sequence = {
'frame_strategy': 'most_unique',
'frame_set': 'snapshot,alarm',
'contig_frames_before_error': 5,
'max_attempts': 3,
'sleep_between_attempts': 0,
'delay_between_frames':0,
'convert_snapshot_to_fid':'yes',
'resize': 'no',
ml_sequence= {
'general': {
'model_sequence': 'object,face',
'disable_locks': '{{disable_locks}}',
'match_past_detections': 'yes',
'past_det_max_diff_area': '15%',
'car_past_det_max_diff_area': '15%',
'object': {
'general':{
'pattern':'{{object_detection_pattern}}',
'same_model_sequence_strategy': 'first' # also 'most', 'most_unique's
'sequence': [{
#First run on TPU with higher confidence
'name': 'TPU object detection',
'enabled': 'yes',
'object_weights':'{{object_weights}}',
'object_labels': '{{object_labels}}',
'object_min_confidence': {{tpu_min_confidence}},
'object_framework':'{{tpu_object_framework}}',
'tpu_max_processes': {{tpu_max_processes}},
'tpu_max_lock_wait': {{tpu_max_lock_wait}},
'max_detection_size':'{{max_detection_size}}',
'show_models':'{{show_models}}'
# YoloV4 on GPU if TPU fails (because sequence strategy is 'first')
'name': 'YoloV4 GPU/CPU',
'enabled': 'yes', # don't really need to say this explictly
'object_config':'{{yolo4_object_config}}',
'object_weights':'{{yolo4_object_weights}}',
'object_labels': '{{yolo4_object_labels}}',
'object_min_confidence': {{object_min_confidence}},
'object_framework':'{{yolo4_object_framework}}',
'object_processor': '{{yolo4_object_processor}}',
'gpu_max_processes': {{gpu_max_processes}},
'gpu_max_lock_wait': {{gpu_max_lock_wait}},
'cpu_max_processes': {{cpu_max_processes}},
'cpu_max_lock_wait': {{cpu_max_lock_wait}},
'face': {
'general':{
'pattern': '{{face_detection_pattern}}',
'pre_existing_labels': ['person'], # when put in general section, it will check if a previous detection type (like object) found this label
'same_model_sequence_strategy': 'union' # combines all outputs of this sequence
'sequence': [
'name': 'TPU face detection',
'enabled': 'yes',
'face_detection_framework': 'tpu',
'face_weights':'/var/lib/zmeventnotification/models/coral_edgetpu/ssd_mobilenet_v2_face_quant_postprocess_edgetpu.tflite',
'face_min_confidence': 0.3,
'name': 'DLIB based face recognition',
'enabled': 'yes',
'pre_existing_labels': ['face'], # If you use TPU detection first, we can run this ONLY if TPU detects a face first
'save_unknown_faces':'{{save_unknown_faces}}',
'save_unknown_faces_leeway_pixels':{{save_unknown_faces_leeway_pixels}},
'face_detection_framework': '{{face_detection_framework}}',
'known_images_path': '{{known_images_path}}',
'unknown_images_path': '{{unknown_images_path}}',
'face_model': '{{face_model}}',
'face_train_model': '{{face_train_model}}',
'face_recog_dist_threshold': '{{face_recog_dist_threshold}}',
'face_num_jitters': '{{face_num_jitters}}',
'face_upsample_times':'{{face_upsample_times}}',
'max_size':800
