Zonemind master 1.37.1~20211007123827-hirsute can't change v4l control settings
bkjaya1952
Post by bkjaya1952 »
I have tested the latest Zoneminder master 1.37.1~20211007123827-hirsute with a web camera .
I have observed that the v4l control settings can not be changed . The error logs are given below .
Screenshot from 2021-10-11 15-43-06.png (282.62 KiB) Viewed 9108 times
Screenshot from 2021-10-11 15-41-46.png (388.71 KiB) Viewed 9108 times
bkjaya1952
Re: Zonemind master 1.37.1~20211007123827-hirsute can't change v4l control settings
The problem still prevails in the latest " Zoneminder-master latest 1.37.1~20211013160809 " as well
Screenshot from 2021-10-14 13-31-46.png (254.42 KiB) Viewed 9036 times
bkjaya1952
The problem still prevails in the latest "Zoneminder-master latest 1.37.1~20211015095620-focal " as well
Screenshot from 2021-10-15 23-09-45.png (296.2 KiB) Viewed 8925 times
Try latest.
We are now using v4l2-ctl to get all the various settings and min/maxes and if it isn't installed, we got no results. I have added back some defaults so behaviour should be restored.
Best to install v4l2-ctl though for best experience.
bkjaya1952
iconnor wrote: Sat Oct 16, 2021 8:47 pm Try latest.
Thank you Sir !
I will try and let you know the results .
