Zoneminder master 1.37.1~20211016164753-impish - can't add monitors[SOLVED]
bkjaya1952
Post by bkjaya1952 »
I have tested 1.37.1~20211016164753-impish on Ubuntu 21.10 (Impish Indri) and found that the monitors can not be created .
No errors were found in the logs.
I suspect that , there may be some issues with the php8.0 which is a default software in Ubuntu 21.10 (Impish Indri).
Screenshot from 2021-10-24 18-09-35.png (200.29 KiB) Viewed 15262 times
Re: Zoneminder master 1.37.1~20211016164753-impish - can't add monitors
Maybe javascript errors?
bkjaya1952
iconnor wrote: Tue Nov 02, 2021 9:08 pm Maybe javascript errors?
Sir,
I have tested the following two versions of Zoneminder master released today and found that only the impish version can't add monitors.
1. Zoneminder-master latest 1.37.1~20211103170857-focal ( php 7.4)
2 Zoneminder-master latest 1.37.1~20211103170857-impish (php 8.0 )
The results for above versions are given below
Screenshot from 2021-11-04 18-41-01.png (333.04 KiB) Viewed 14540 times
Figure: 1 Zoneminder-master latest 1.37.1~20211103170857-focal ( php 7.4)
Screenshot from 2021-11-04 15-28-25.png (202.54 KiB) Viewed 14540 times
Figure: 2 Zoneminder-master latest 1.37.1~20211103170857-impish (php 8.0 )
Apparently there may be some issues with php when you consider the above outcomes ,
Okay, but I am running impish on several machines and they all work. Granted they are upgrades not fresh installs.
There has to be errors logged, either in web_php.log, or apache logs or javascript console.
bkjaya1952
Re: Zoneminder master 1.37.1~20211016164753-impish - can't add monitors[ SOLVED]
bkjaya1952 wrote: Sun Oct 24, 2021 12:48 pm I have tested 1.37.1~20211016164753-impish on Ubuntu 21.10 (Impish Indri) and found that the monitors can not be created .
bkjaya1952
Re: Zoneminder master 1.37.1~20211016164753-impish [SOLVED} - can't add monitors
bkjaya1952
iconnor wrote: Thu Nov 04, 2021 6:54 pm Okay, but I am running impish on several machines and they all work. Granted they are upgrades not fresh installs.
Thank you very much Sir !
The problem has been solved in the latest version of Zoneminder mastaer Zoneminder-master latest 1.37.3~20211124134504- impish released today !
Screenshot from 2021-11-25 19-30-15.png (325.14 KiB) Viewed 13275 times
