[Solved]Email notification include mpeg video rather than avi
lyallp
Post by lyallp »
What settings need tweaking such that emails are sent with mpeg video files rather than avi?
Whilst I am all good with every other part of the email system, everything else seems fine, I can see view the avi file in my Thunderbird email client on Linux, I can't view the avi file on my iPhone.
...Lyall
lyallp
Re: Email notification include mpeg video rather than avi
Post by lyallp »
Ok, I have found the settings to change from avi to mpg (not mpeg, as my browser thinks it's audio)
Options -> Images -> FFMPEG_FORMATS = mpg* mpeg wmv asf avi mov** swf 3gp
Also, the message that is sent, I found a few of the %XXX% fields don't work.
(I copied/pasted the entire list from the doco and then tweaked it into a HTML table)
The following 'fields' seem to generate no data, when the email is generated by my filter.
  • Total number of events for the monitor (%MET%)
    Number of events: hour, day, week, month (%MEH%, %MED%, %MEW%, %MEM%)
My email template is as follows:-
<!DOCTYPE html>
<html>
  <head>
<style>
table {
  font-family: arial, sans-serif;
  border-collapse: collapse;
  width: 100%;
td, th {
  border: 1px solid #dddddd;
  text-align: left;
  padding: 8px;
tr:nth-child(even) {
  background-color: #dddddd;
</style>
<h2>Zoneminder detected motion in the back yard.</h2>
Check out <a href="http://lyalls-pc.at.the-pearces.com/zm">ZoneMinder</a>
</head>
<body>
<table style="width:90%">
<tr>
 <th>Item</th>
 <th>Value</th>
</tr>
<tr><td>Event description						</td><td>%ED% </td></tr>
<tr><td>Time of the event					</td><td>%ET% </td></tr>
<tr><td><a href="%EP%"  >Event</a>				</td><td>     </td></tr>
<tr><td><a href="%EPI1%">First alarmed event image</a>		</td><td></td></tr>
<tr><td><a href="%EPIM%">(first) Event image with the highest score</a></td><td></td></tr>
<tr><td>Id of the event						</td><td>%EI% </td></tr>
<tr><td>Name of the event					</td><td>%EN% </td></tr>
<tr><td>Cause of the event					</td><td>%EC% </td></tr>
<tr><td>Length of the event					</td><td>%EL% </td></tr>
<tr><td>Event : Frames, Alarm Frames			</td><td>%EF%, %EFA% </td></tr>
<tr><td>Event Score: Total, Average and Maximum	</td><td>%EST%, %ESA%, %ESM% </td></tr>
<tr><td>Name of the monitor					</td><td>%MN% </td></tr>
<tr><td>Total number of events for the monitor		</td><td>%MET%</td></tr>
<tr><td>Number of events: hour, day, week, month	</td><td>%MEH%, %MED%, %MEW%, %MEM% </td></tr>
<tr><td><a href="%MP%" >Monitor window</a>		</td><td></td></tr>
<tr><td>Name of the Current Filter				</td><td>%FN% </td></tr>
<tr><td><a href="%FP%">Filter that matched</a>		</td><td></td></tr>
<tr><td><a href="%ZP%">ZoneMinder console</a>		</td><td></td></tr>
<tr><td>First alarmed event image <b>attached</b>		</td><td>%EI1%</td></tr>
<tr><td>Image with the highest score <b>attached</b>	</td><td>%EIM%</td></tr>
<tr><td>Event mpeg video <b>attached</b>			</td><td>%EV% </td></tr>
</table>
</body>
</html>
...Lyall
Thanks for noticing and reporting! Fixed in master, will be in 1.36.11.
lyallp
Post by lyallp »
Found correct settings for iPhone to view video as an email attachment.
Options -> Images -> FFMPEG_FORMATS = m4v* mpeg wmv asf avi mov** swf 3gp
Given ffmpeg is awesome and knows just about every media file suffix there is, I thought I would try m4v, and it works, for my iPhone and for my linux system.
...Lyall
