I'm experiencing download problem when i try to download more than one video. I receive an empty zip/tar file, i mean there is no video inside. But if i download a single record then it works fine. I have upgraded to 1.36.10-focal1 release from 1.36.9 but nothing have changed. My OS is Ubuntu 20.04.3 LTS (5.4.0.89-generic).
Regards,
Nurettin Akhan
ZM 1.36.10 multiple video download problem [SOLVED]
- zm_empty_zip.png (31.14 KiB) Viewed 8172 times
Last edited by nurettinakhan on Fri Jan 14, 2022 12:30 pm, edited 2 times in total.
Re: ZM 1.36.10 multiple video download problem
I have tried this too.
I selected 2 events from a list. Both events were archived.
Zoneminder v1.37.1 on Gentoo Linux.
Archive (tar), that was generated attached.
- zmExport_913991.tar
- (100 KiB) Downloaded 91 times
...Lyall
1.36.9 and I do get empty files all the time (on single or multiple events.)
Attached example
Attached example
- zmExport_35277.zip
- (95.71 KiB) Downloaded 89 times
I'm still looking for a solution.
Is there any one who is not facing with the same problem in last 2 releases ?
I'd work around it. If you have the MP4 files on the server, just grab them from there.
I think I finally found the problem and released 1.36.11 with the fix. Packages building.
