[Solved]Insert into frames failed - rather large syslog error
lyallp
Post by lyallp »
I noticed my syslog suddenly scrolling by.
It appears there is some sort of issue with ZM and the database.
I suspect it is driven by the fact that I have a concurrent filter which deletes events if they are less than 50 alarm frames.
I never understood why 'Lock rows' was needed, is this a case where the filter needs to do just that? Should I enable lock rows in my filters?
Following, is what appears to be a 'set' of errors, based on the time of the errors being somewhat consecutive.
It should be noted, according to the ZM UI, there is no such event as 470.
Oct 29 08:04:01 Lyalls-PC CROND[32107]: (lyall) CMDEND (/home/lyall/Scripts/DownloadPowerGatewayInfo.py)
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00206-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Failed to write frame image]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00207-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00208-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00209-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00210-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00211-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00212-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00213-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00214-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00215-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00216-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00217-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00218-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00219-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00220-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00221-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00222-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00223-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00224-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00225-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00226-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00227-capture.jpg for writing: No such file or directory]
Oct 29 08:04:30 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00228-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00229-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Failed to write frame image]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00230-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00231-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00232-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00233-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't run query INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES  ( 470, 204, 'Normal', from_unixtime( 1635456870 ), 6.76, 0 ), ( 470, 205, 'Normal', from_unixtime( 1635456870 ), 6.79, 0 ), ( 470, 206, 'Normal', from_unixtime( 1635456870 ), 6.83, 0 ), ( 470, 207, 'Normal', from_unixtime( 1635456870 ), 6.86, 0 ), ( 470, 208, 'Normal', from_unixtime( 1635456870 ), 6.90, 0 ), ( 470, 209, 'Normal', from_unixtime( 1635456870 ), 6.94, 0 ), ( 470, 210, 'Normal', from_unixtime( 1635456870 ), 6.97, 0 ), ( 470, 211, 'Normal', from_unixtime( 1635456870 ), 7.00, 0 ), ( 470, 212, 'Normal', from_unixtime( 1635456870 ), 7.02, 0 ), ( 470, 213, 'Normal', from_unixtime( 1635456870 ), 7.06, 0 ), ( 470, 214, 'Normal', from_unixtime( 1635456870 ), 7.09, 0 ), ( 470, 215, 'Normal', from_unixtime( 1635456870 ), 7.13, 0 ), ( 470, 216, 'Normal', from_unixtime( 1635456870 ), 7.16, 0 ), ( 470, 217, 'Normal', from_unixtime( 1635456870 ), 7.19, 0 ), ( 470, 218, 'Normal', from_unixtime( 1635456870 ), 7.22, 0 ), ( 470, 219, 'Normal', from_unixtime( 1635456870 ), 7.26, 0 ), ( 470, 220, 'Normal', from_unixtime( 1635456870 ), 7.29, 0 ), ( 470, 221, 'Normal', from_unixtime( 1635456870 ), 7.33, 0 ), ( 470, 222, 'Normal', from_unixtime( 1635456870 ), 7.36, 0 ), ( 470, 223, 'Normal', from_unixtime( 1635456870 ), 7.39, 0 ), ( 470, 224, 'Normal', from_unixtime( 1635456870 ), 7.43, 0 ), ( 470, 225, 'Normal', from_unixtime( 1635456870 ), 7.45, 0 ), ( 470, 226, 'Normal', from_unixtime( 1635456870 ), 7.48, 0 ), ( 470, 227, 'Normal', from_unixtime( 1635456870 ), 7.53, 0 ), ( 470, 228, 'Normal', from_unixtime( 1635456870 ), 7.57, 0 ), ( 470, 229, 'Normal', from_unixtime( 1635456870 ), 7.60, 0 ), ( 470, 230, 'Normal', from_unixtime( 1635456871 ), 7.64, 0 ), ( 470, 231, 'Normal', from_unixtime( 1635456871 ), 7.67, 0 ), ( 470, 232, 'Normal', from_unixtime( 1635456871 ), 7.71, 0 ), ( 470, 233, 'Normal', from_unixtime( 1635456871 ), 7.74, 0 ): Cannot add or update a
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00234-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't run query INSERT INTO `Stats` (`EventId`, `FrameId`, `MonitorId`, `ZoneId`, `PixelDiff`, `AlarmPixels`, `FilterPixels`, `BlobPixels`,`Blobs`,`MinBlobSize`, `MaxBlobSize`, `MinX`, `MinY`, `MaxX`, `MaxY`,`Score`) VALUES  (470,204,2,5,16,657,0,0,0,0,0,0,0,0,0,0), (470,205,2,5,16,678,0,0,0,0,0,0,0,0,0,0), (470,206,2,5,16,657,0,0,0,0,0,0,0,0,0,0), (470,207,2,5,16,716,0,0,0,0,0,0,0,0,0,0), (470,208,2,5,16,680,0,0,0,0,0,0,0,0,0,0), (470,209,2,5,16,597,0,0,0,0,0,0,0,0,0,0), (470,210,2,5,16,628,0,0,0,0,0,0,0,0,0,0), (470,211,2,5,16,642,0,0,0,0,0,0,0,0,0,0), (470,212,2,5,16,655,0,0,0,0,0,0,0,0,0,0), (470,213,2,5,16,662,0,0,0,0,0,0,0,0,0,0), (470,214,2,5,16,661,0,0,0,0,0,0,0,0,0,0), (470,215,2,5,16,651,0,0,0,0,0,0,0,0,0,0), (470,216,2,5,16,653,0,0,0,0,0,0,0,0,0,0), (470,217,2,5,16,654,0,0,0,0,0,0,0,0,0,0), (470,218,2,5,16,638,0,0,0,0,0,0,0,0,0,0), (470,219,2,5,16,658,0,0,0,0,0,0,0,0,0,0), (470,220,2,5,16,647,0,0,0,0,0,0,0,0,0,0), (470,221,2,5,16,647,0,0,0,0,0,0,0,0,0,0), (470,222,2,5,16,573,0,0,0,0,0,0,0,0,0,0), (470,223,2,5,16,684,0,0,0,0,0,0,0,0,0,0), (470,224,2,5,16,687,0,0,0,0,0,0,0,0,0,0), (470,225,2,5,16,670,0,0,0,0,0,0,0,0,0,0), (470,226,2,5,16,670,0,0,0,0,0,0,0,0,0,0), (470,227,2,5,16,703,0,0,0,0,0,0,0,0,0,0), (470,228,2,5,16,739,0,0,0,0,0,0,0,0,0,0), (470,229,2,5,16,719,0,0,0,0,0,0,0,0,0,0), (470,230,2,5,16,682,0,0,0,0,0,0,0,0,0,0), (470,231,2,5,16,695,0,0,0,0,0,0,0,0,0,0), (470,232,2,5,16,698,0,0,0,0,0,0,0,0,0,0), (470,233,2,5,16,739,0,0,0,0,0,0,0,0,0,0): Cannot add or update a child row: a foreign key constraint fails (`zm`.`Stats`, CONSTRAINT `Stats_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00235-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00236-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00237-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00238-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00239-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00240-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00241-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00242-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00243-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00244-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00245-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00246-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00247-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00248-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00249-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00250-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00251-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00252-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00253-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00254-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00255-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00256-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00257-capture.jpg for writing: No such file or directory]
Oct 29 08:04:31 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00258-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00259-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Failed to write frame image]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00260-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00261-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00262-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00263-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't run query INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES  ( 470, 234, 'Normal', from_unixtime( 1635456871 ), 7.77, 0 ), ( 470, 235, 'Normal', from_unixtime( 1635456871 ), 7.81, 0 ), ( 470, 236, 'Normal', from_unixtime( 1635456871 ), 7.84, 0 ), ( 470, 237, 'Normal', from_unixtime( 1635456871 ), 7.87, 0 ), ( 470, 238, 'Normal', from_unixtime( 1635456871 ), 7.90, 0 ), ( 470, 239, 'Normal', from_unixtime( 1635456871 ), 7.94, 0 ), ( 470, 240, 'Normal', from_unixtime( 1635456871 ), 7.97, 0 ), ( 470, 241, 'Normal', from_unixtime( 1635456871 ), 8.00, 0 ), ( 470, 242, 'Normal', from_unixtime( 1635456871 ), 8.03, 0 ), ( 470, 243, 'Normal', from_unixtime( 1635456871 ), 8.06, 0 ), ( 470, 244, 'Normal', from_unixtime( 1635456871 ), 8.09, 0 ), ( 470, 245, 'Normal', from_unixtime( 1635456871 ), 8.13, 0 ), ( 470, 246, 'Normal', from_unixtime( 1635456871 ), 8.16, 0 ), ( 470, 247, 'Normal', from_unixtime( 1635456871 ), 8.19, 0 ), ( 470, 248, 'Normal', from_unixtime( 1635456871 ), 8.23, 0 ), ( 470, 249, 'Normal', from_unixtime( 1635456871 ), 8.26, 0 ), ( 470, 250, 'Normal', from_unixtime( 1635456871 ), 8.30, 0 ), ( 470, 251, 'Normal', from_unixtime( 1635456871 ), 8.33, 0 ), ( 470, 252, 'Normal', from_unixtime( 1635456871 ), 8.36, 0 ), ( 470, 253, 'Normal', from_unixtime( 1635456871 ), 8.39, 0 ), ( 470, 254, 'Normal', from_unixtime( 1635456871 ), 8.42, 0 ), ( 470, 255, 'Normal', from_unixtime( 1635456871 ), 8.46, 0 ), ( 470, 256, 'Normal', from_unixtime( 1635456871 ), 8.50, 0 ), ( 470, 257, 'Normal', from_unixtime( 1635456871 ), 8.53, 0 ), ( 470, 258, 'Normal', from_unixtime( 1635456871 ), 8.56, 0 ), ( 470, 259, 'Normal', from_unixtime( 1635456871 ), 8.60, 0 ), ( 470, 260, 'Normal', from_unixtime( 1635456872 ), 8.64, 0 ), ( 470, 261, 'Normal', from_unixtime( 1635456872 ), 8.67, 0 ), ( 470, 262, 'Normal', from_unixtime( 1635456872 ), 8.70, 0 ), ( 470, 263, 'Normal', from_unixtime( 1635456872 ), 8.74, 0 ): Cannot add or update a
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00264-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't run query INSERT INTO `Stats` (`EventId`, `FrameId`, `MonitorId`, `ZoneId`, `PixelDiff`, `AlarmPixels`, `FilterPixels`, `BlobPixels`,`Blobs`,`MinBlobSize`, `MaxBlobSize`, `MinX`, `MinY`, `MaxX`, `MaxY`,`Score`) VALUES  (470,234,2,5,16,748,0,0,0,0,0,0,0,0,0,0), (470,235,2,5,16,687,0,0,0,0,0,0,0,0,0,0), (470,236,2,5,16,685,0,0,0,0,0,0,0,0,0,0), (470,237,2,5,16,802,0,0,0,0,0,0,0,0,0,0), (470,238,2,5,16,798,0,0,0,0,0,0,0,0,0,0), (470,239,2,5,16,925,0,0,0,0,0,0,0,0,0,0), (470,240,2,5,16,1343,36,0,0,0,0,0,0,0,0,0), (470,241,2,5,16,1476,49,0,0,0,0,0,0,0,0,0), (470,242,2,5,16,1023,4,0,0,0,0,0,0,0,0,0), (470,243,2,5,16,754,0,0,0,0,0,0,0,0,0,0), (470,244,2,5,16,682,0,0,0,0,0,0,0,0,0,0), (470,245,2,5,16,669,0,0,0,0,0,0,0,0,0,0), (470,246,2,5,16,730,0,0,0,0,0,0,0,0,0,0), (470,247,2,5,16,720,0,0,0,0,0,0,0,0,0,0), (470,248,2,5,16,726,0,0,0,0,0,0,0,0,0,0), (470,249,2,5,16,700,0,0,0,0,0,0,0,0,0,0), (470,250,2,5,16,690,0,0,0,0,0,0,0,0,0,0), (470,251,2,5,16,770,0,0,0,0,0,0,0,0,0,0), (470,252,2,5,16,727,0,0,0,0,0,0,0,0,0,0), (470,253,2,5,16,762,0,0,0,0,0,0,0,0,0,0), (470,254,2,5,16,780,0,0,0,0,0,0,0,0,0,0), (470,255,2,5,16,749,0,0,0,0,0,0,0,0,0,0), (470,256,2,5,16,723,0,0,0,0,0,0,0,0,0,0), (470,257,2,5,16,756,0,0,0,0,0,0,0,0,0,0), (470,258,2,5,16,769,0,0,0,0,0,0,0,0,0,0), (470,259,2,5,16,776,0,0,0,0,0,0,0,0,0,0), (470,260,2,5,16,765,0,0,0,0,0,0,0,0,0,0), (470,261,2,5,16,786,0,0,0,0,0,0,0,0,0,0), (470,262,2,5,16,761,0,0,0,0,0,0,0,0,0,0), (470,263,2,5,16,769,0,0,0,0,0,0,0,0,0,0): Cannot add or update a child row: a foreign key constraint fails (`zm`.`Stats`, CONSTRAINT `Stats_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00265-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00266-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00267-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00268-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00269-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00270-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00271-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00272-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00273-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00274-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00275-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00276-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00277-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00278-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00279-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00280-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00281-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00282-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00283-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00284-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00285-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00286-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00287-capture.jpg for writing: No such file or directory]
Oct 29 08:04:32 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00288-capture.jpg for writing: No such file or directory]
Oct 29 08:04:33 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't open /var/lib/zoneminder/events/2/2021-10-29/470/00289-capture.jpg for writing: No such file or directory]
Oct 29 08:04:33 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Failed to write frame image]
Oct 29 08:04:33 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't run query INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES  ( 470, 264, 'Normal', from_unixtime( 1635456872 ), 8.77, 0 ), ( 470, 265, 'Normal', from_unixtime( 1635456872 ), 8.80, 0 ), ( 470, 266, 'Normal', from_unixtime( 1635456872 ), 8.84, 0 ), ( 470, 267, 'Normal', from_unixtime( 1635456872 ), 8.87, 0 ), ( 470, 268, 'Normal', from_unixtime( 1635456872 ), 8.90, 0 ), ( 470, 269, 'Normal', from_unixtime( 1635456872 ), 8.94, 0 ), ( 470, 270, 'Normal', from_unixtime( 1635456872 ), 8.97, 0 ), ( 470, 271, 'Normal', from_unixtime( 1635456872 ), 9.00, 0 ), ( 470, 272, 'Normal', from_unixtime( 1635456872 ), 9.03, 0 ), ( 470, 273, 'Normal', from_unixtime( 1635456872 ), 9.06, 0 ), ( 470, 274, 'Normal', from_unixtime( 1635456872 ), 9.09, 0 ), ( 470, 275, 'Normal', from_unixtime( 1635456872 ), 9.13, 0 ), ( 470, 276, 'Normal', from_unixtime( 1635456872 ), 9.16, 0 ), ( 470, 277, 'Normal', from_unixtime( 1635456872 ), 9.19, 0 ), ( 470, 278, 'Normal', from_unixtime( 1635456872 ), 9.23, 0 ), ( 470, 279, 'Normal', from_unixtime( 1635456872 ), 9.26, 0 ), ( 470, 280, 'Normal', from_unixtime( 1635456872 ), 9.29, 0 ), ( 470, 281, 'Normal', from_unixtime( 1635456872 ), 9.33, 0 ), ( 470, 282, 'Normal', from_unixtime( 1635456872 ), 9.36, 0 ), ( 470, 283, 'Normal', from_unixtime( 1635456872 ), 9.39, 0 ), ( 470, 284, 'Normal', from_unixtime( 1635456872 ), 9.43, 0 ), ( 470, 285, 'Normal', from_unixtime( 1635456872 ), 9.46, 0 ), ( 470, 286, 'Normal', from_unixtime( 1635456872 ), 9.49, 0 ), ( 470, 287, 'Normal', from_unixtime( 1635456872 ), 9.53, 0 ), ( 470, 288, 'Normal', from_unixtime( 1635456872 ), 9.56, 0 ), ( 470, 289, 'Normal', from_unixtime( 1635456872 ), 9.59, 0 ): Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
Oct 29 08:04:33 Lyalls-PC zmc_dvideo0[6449]: ERR [zmc_dvideo0] [Can't run query INSERT INTO `Stats` (`EventId`, `FrameId`, `MonitorId`, `ZoneId`, `PixelDiff`, `AlarmPixels`, `FilterPixels`, `BlobPixels`,`Blobs`,`MinBlobSize`, `MaxBlobSize`, `MinX`, `MinY`, `MaxX`, `MaxY`,`Score`) VALUES  (470,264,2,5,16,771,0,0,0,0,0,0,0,0,0,0), (470,265,2,5,16,843,0,0,0,0,0,0,0,0,0,0), (470,266,2,5,16,802,0,0,0,0,0,0,0,0,0,0), (470,267,2,5,16,876,0,0,0,0,0,0,0,0,0,0), (470,268,2,5,16,904,0,0,0,0,0,0,0,0,0,0), (470,269,2,5,16,1022,3,0,0,0,0,0,0,0,0,0), (470,270,2,5,16,951,0,0,0,0,0,0,0,0,0,0), (470,271,2,5,16,817,0,0,0,0,0,0,0,0,0,0), (470,272,2,5,16,803,0,0,0,0,0,0,0,0,0,0), (470,273,2,5,16,855,0,0,0,0,0,0,0,0,0,0), (470,274,2,5,16,845,0,0,0,0,0,0,0,0,0,0), (470,275,2,5,16,820,0,0,0,0,0,0,0,0,0,0), (470,276,2,5,16,859,0,0,0,0,0,0,0,0,0,0), (470,277,2,5,16,870,0,0,0,0,0,0,0,0,0,0), (470,278,2,5,16,865,0,0,0,0,0,0,0,0,0,0), (470,279,2,5,16,860,0,0,0,0,0,0,0,0,0,0), (470,280,2,5,16,861,0,0,0,0,0,0,0,0,0,0), (470,281,2,5,16,828,0,0,0,0,0,0,0,0,0,0), (470,282,2,5,16,828,0,0,0,0,0,0,0,0,0,0), (470,283,2,5,16,876,0,0,0,0,0,0,0,0,0,0), (470,284,2,5,16,846,0,0,0,0,0,0,0,0,0,0), (470,285,2,5,16,841,0,0,0,0,0,0,0,0,0,0), (470,286,2,5,16,918,0,0,0,0,0,0,0,0,0,0), (470,287,2,5,16,863,0,0,0,0,0,0,0,0,0,0), (470,288,2,5,16,980,0,0,0,0,0,0,0,0,0,0), (470,289,2,5,16,961,0,0,0,0,0,0,0,0,0,0): Cannot add or update a child row: a foreign key constraint fails (`zm`.`Stats`, CONSTRAINT `Stats_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
...Lyall
Re: Insert into frames failed - rather large syslog error
One of your filters deleted an in process event. You might at least add an EndDate/Time is NOT NULL term.
lyallp
Post by lyallp »
Awesome, such a quick reply.
So, locking is not the issue. I will tweak the filters.
Thanks!
...Lyall
