Blurams Dome Lite 2
chuck8530
Blurams Dome Lite 2
Post by chuck8530 »
Tilt/Pan 1296x2384. Has IP, Can display via Blurams Android app. suggestions to add to ZM.
thanks
Re: Blurams Dome Lite 2
Do you get anything if you just enter the ip in a browser?
Check the iSpy database for clues.
chuck8530
Post by chuck8530 »
nmap -T4 -A 192.168.0.191
Starting Nmap 7.80 ( https://nmap.org ) at 2021-11-20 21:34 MST
Nmap scan report for 192.168.0.191
Host is up (0.0081s latency).
All 1000 scanned ports on 192.168.0.191 are closed
MAC Address: 24:18:C6:65:50:B5 (Unknown)
Too many fingerprints match this host to give specific OS details
Network Distance: 1 hop
TRACEROUTE
HOP RTT ADDRESS
1 8.12 ms 192.168.0.191
can ping. browser - "Unable to Connect"
Wasn't my pick/purchase - (her to watch dogs)
Impossible with these cloud cameras. Some have alternative firmware that supports RTSP.
chuck8530
Post by chuck8530 »
thanks
*Some* cloud cams will work. Here's a couple I use.
rtsp://admin:@192.168.1.211/0/av1
rtsp://admin:<pwd>@192.168.1.213:8554/profile1
rtsp://admin:<pwd>@192.168.1.207/onvif1
I find you sometimes need to reboot the cam after a failure, 'cuz it locks out further attempts, until you do.
