Question to Pi4b performance and camera resolution
Posted: Tue Nov 23, 2021 8:06 am
I'm using ZM 1.36.11 on bullseye 32bit (before with buster - no differences) and a raspi 4GB and 128GB sd card.
I have 2 720p cameras using ffmpeg and rtsp.
The cpu load avarage is about 1.4, memory usage 1.2GB and everything is working fine. Live view and recordings are fluent (live view in ZM is 1-3 seconds later - thats ok)
Now I'm planning to add a third camera, but currently the cameras are mostly at least 1080p
I tested 2 different 1080p cameras (rtsp) and I got a cpu average about 2, but there was a huge lag in live view for this camera (30-45 seconds).
Unfortunately I couldn't configure the rtsp stream very well with these test cameras.
Is this too much for the raspi? Or would e.g. using an USB SSD improve this?
Or shall I try to find a camera that I can configure to 720p?
Or can someone recommend a camera about 100Eur?
Can someone give me some tipps?
thank you
André
thank you
André
