FPS Counters (Wyze Cam v2 RTSP)
Posted: Wed Dec 01, 2021 2:53 am
Is there any documentation on the fps counters in the bottom of the monitor web console (i.e. http://host/zm/index.php?view=watch&mid=5)?
I see three values. One I believe is the fps of the viewer, the other I think is capture fps, and the last I think is the analysis fps...is this right?
I have an issue with Wyze Cam v2 stock RTSP in which the last two are fine (they match the camera specs) but the first one is horrible (i.e. 0-2 fps) and its obvious that the viewer image is stuttering. I have tried all sorts of buffer changes but nothing seems to help. When playing back events, they are perfect.
And to put the cherry on top - Wyze Cam v3 stock RTSP does not cause the issue. Also Dafang Hacks cams are perfect.
This only us happening on my v2's and its on all of them.
Can anyone point me in the right direction? I'd like the monitor fps to not be so choppy when using zmninja or even the web interface
