Button mapping for ptz control - Hikvision
Pedulla
Post by Pedulla »
Running 1.36.7 on Ubuntu LEMP stack.
I'm using the stock Hikvision control script. This issue seems to be a Web Interface problem.
Specifically, if you press the left part of the pan left button the cam moves left (as it should) if you click on the right side of the pan LEFT button the camera moves right. Clicking the pan right button moves right as well.
All of this is proportional the further you go in either direction the faster it moves. It's just that the cut-over point from left to right is in the middle of the left pan button.
This started for me with the upgrade from 1.36 to 1.36, I'm just now getting time to address it here.
Anyone else seeing this?
Pedulla
Re: Button mapping for ptz control - Hikvision
Post by Pedulla »
PS. The web-site monitor type that used to allow this: viewtopic.php?f=38&t=27622&p=108322&hil ... tz#p108322 is no longer working so getting the ZM buttons to work would be great.
