Page 1 of 1
How to upgrade zoneminder ?
Posted: Sun Dec 19, 2021 6:43 am
by david1234
I'm running zonminder on my PI4 (did the installation as it say in the zoneminder Wiki)
the version is 1.32.3
do I need to upgrade it ?
how do I upgrdae it ?
and if I upgrade it - will it save all the configuration ? or I will need to setup everything again ?
Thanks ,
Re: How to upgrade zoneminder ?
Posted: Sun Dec 19, 2021 9:28 am
by dougmccrary
Not if it's working for you. There are some pretty cool new features, though.
Change your source from zoneminder-1.32/whatever to zoneminder-1.34 or 1.36
Usually, yes, so no.
But it's a good idea not to jump directly from 1.32 to 1.36. 1.32 to 1.34 to 1.36 is less chancy.
You probably want to save your database, just in case.
Posted: Sun Dec 19, 2021 1:24 pm
by david1234
OK
alsmost everything is working for me - I mange to get 100% of what i want\need.
so I prefer not to touch it - if it's not broken no need to fix
thank you for the explain and answer
Posted: Mon Dec 20, 2021 3:25 am
by dougmccrary
Egg-zactly.
Posted: Tue Jan 25, 2022 10:55 am
by pimehexon
dougmccrary wrote: ↑Sun Dec 19, 2021 9:28 am
What should I do if I upgraded zoneminder and lost all my data? Is there any way to resrore all configurations and cancel changes?
Posted: Wed Jan 26, 2022 6:44 am
by dougmccrary
Restore/cancel
Depends on what happened. Unless you really need whatever data was lost, probably best to just forget it and forge on.
Settings are quite a bit improved just using ffmpeg and auto in most cases.
