Unable to send error email in zmfilter.pl
frankz66
Post by frankz66 »
Hello everyone, I installed the Zoneminder distro on a ubuntu 20.04 server via the ppa:iconnor/zoneminder-master repository
At the moment I can't make filter email sending work, which I regularly copied from a zoneminder distro in LXC.
I did several tests and the error that signals me is:
Sudo zmfilter.pl --filter_id=3
Use of uninitialized value in subtraction (-) at /usr/bin/zmfilter.pl line 187.
I attach an image for the filter I created.
v1.37.6
Re: Unable to send error email in zmfilter.pl
Your zmfilter command is for filter #3 and the screen grab for #4.
There is a section for 1.37 Dev version - viewforum.php?f=44
frankz66
Post by frankz66 »
Thank you for your reply, I pre-installed version 1.36 and everything works regularly, except that the server link and its event are not presented to me in the alerts. Can you help me?
Here it is:
ZM alarm detected - 9.33 secs, 237/17 frames, t44/m3/a2 score.
frankz66
Post by frankz66 »
Yes, that's right, I get the emails but without the link to the event. In the previous and other version you need to arrive correctly. So now I find the notifications but without the possibility to click on the event to see it live.
Add the appropriate token from that documentation to do what you want.
frankz66
Post by frankz66 »
Sorry, what do you mean tokens? Or can you give me an example of a string?
The tokens listed in the link given a couple posts up.
frankz66
Post by frankz66 »
Hello and thank you. I solved it anyway, I added the %EPS% variable in the email filters, and the video link arrives
