zmtrigger on Nodect without analysis-decoding
bspiegel
Post by bspiegel »
It seems zmtrigger works fine when analysis and decoding are enabled but fails to work if they are not.
I use zmtrigger to start events and specify a specific trigger cause. However, I like running with analysis/enabled off to reduce CPU.
I have found that zmu can trigger an event but there is not a way to specify the cause.
Any advice on how to trigger and record cause? I'd love to see zmtrigger work without analysis/decoding.
