How can I create a filter based on object detection (person, car, bike, etc)
JCAK
Post by JCAK »
I want execute a script file when the event match with a object detection, for example: person >= 60%
I don't know how achieve this, because ZM filter don't have an option to create a filter based on objects detections (person, car, bike, etc)
I'm reading on event server documentation, have "event_start_hook_notify_userscript" , "event_end_hook_notify_userscript" and "event_end_hook" but I don't know how to use, I can't understand the examples and not found nothing more on web.
Could someone help me please.
Thanks.
Re: How can I create a filter based on object detection (person, car, bike, etc)
I wouldn't, I use Pushover for that.
If you want a filter, use the Notes field. That can look for the term 'Person'. Set the thresholds in ZMES.
add a rule for Notes contains....
JCAK
Post by JCAK »
iconnor wrote: Tue Jan 25, 2022 2:55 pm add a rule for Notes contains....
Notes was my first try, I could search for the text "Persons" inside Notes, but doesn't have or I can't found a way to create a condition which trigger the filter in background only if Person >=60%
How can I read "percent" and create a condition ?
shane_pcs
Post by shane_pcs »
You need to limit your confidence in ZMES the objectconfig i think. 'object_min_confidence' if you set to 60 it will only label the notes if its above 60% confident. Then your filter based on notes with person will trigger any time there is a person detected.
Agreed and 60% might not be enough, IME.
JCAK
Post by JCAK »
shane_pcs wrote: Thu Jan 27, 2022 3:25 pm You need to limit your confidence in ZMES the objectconfig i think. 'object_min_confidence' if you set to 60 it will only label the notes if its above 60% confident. Then your filter based on notes with person will trigger any time there is a person detected.
Thank you, is a good idea, I will try.
It is a pity that the percent value is not stored in a numeric field in the database, because there is no way to create custom SQL queries and then manually insert it into the database filter table.
It's to be expected as they are two separate projects. They could be more tightly integrated I suppose. Putting some money up would help.
