1.37.11 main - big improvement - Thanks!
Still having the image corruption when watching events of Actual size or larger, but from my perspective, everything else is back to working.
...Lyall
Re: 1.37.11 main - big improvement - Thanks!
Hi
but it's not working for me (All camera not running)... Debian Bullseye Last Stable Version ... ZM Version: 1.37.11~20220203.75-bullseye
2022-02-03 15:03:54 zmdc 1020 ERR 'zmc -m 11' exited abnormally, exit status 255 zmdc.pl -
2022-02-03 15:03:54 zmc_m11 9623 ERR No monitors found zmc.cpp 212
2022-02-03 15:03:54 zmc_m11 9623 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 15:03:54 zmc_m11 9623 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
2022-02-03 15:03:54 zmdc 9623 INF 'zmc -m 11' started at 22/02/03 15:03:54 zmdc.pl -
2022-02-03 15:03:54 zmdc 1020 INF 'zmc -m 11' starting at 22/02/03 15:03:54, pid = 9623 zmdc.pl -
2022-02-03 15:03:54 zmdc 1020 INF Starting pending process, zmc -m 11 zmdc.pl -
2022-02-03 15:03:53 zmdc 1020 ERR 'zmc -m 10' exited abnormally, exit status 255 zmdc.pl -
2022-02-03 15:03:53 zmc_m10 9620 ERR No monitors found zmc.cpp 212
2022-02-03 15:03:53 zmc_m10 9620 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 15:03:53 zmc_m10 9620 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
2022-02-03 15:03:53 zmdc 9620 INF 'zmc -m 10' started at 22/02/03 15:03:53 zmdc.pl -
2022-02-03 15:03:53 zmdc 1020 INF 'zmc -m 10' starting at 22/02/03 15:03:53, pid = 9620 zmdc.pl -
2022-02-03 15:03:53 zmdc 1020 INF Starting pending process, zmc -m 10 zmdc.pl -
2022-02-03 15:03:52 zmdc 1020 ERR 'zmc -m 6' exited abnormally, exit status 255 zmdc.pl -
2022-02-03 15:03:52 zmdc 1020 ERR 'zmc -m 8' exited abnormally, exit status 255 zmdc.pl -
2022-02-03 15:03:52 zmc_m6 9612 ERR No monitors found zmc.cpp 212
Uh... that capturing stuff is from an experimental branch of mine... I think it must be building packages from it. Not good.
Should be some new packages available in a few minutes that are true master.
Hi Thanks !
I tried the new update(1.37.11~20220203.86-bullseye) and it's still not running
2022-02-03 21:43:12 zms_m1 4290 ERR Unable to load monitor id 1 for streaming zm_stream.cpp 45
2022-02-03 21:43:12 zms_m1 4290 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 21:43:12 zms_m1 4290 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
2022-02-03 21:43:12 zms_m2 4288 ERR Unable to load monitor id 2 for streaming zm_stream.cpp 45
2022-02-03 21:43:12 zms_m2 4288 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 21:43:12 zms_m2 4288 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
2022-02-03 21:43:09 zmdc 1031 ERR 'zmc -m 11' exited abnormally, exit status 255 zmdc.pl -
2022-02-03 21:43:09 zmc_m11 4286 ERR No monitors found zmc.cpp 212
2022-02-03 21:43:09 zmc_m11 4286 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 21:43:09 zmc_m11 4286 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
2022-02-03 21:43:09 zmdc 4286 INF 'zmc -m 11' started at 22/02/03 21:43:09 zmdc.pl -
2022-02-03 21:43:09 zmdc 1031 INF 'zmc -m 11' starting at 22/02/03 21:43:09, pid = 4286 zmdc.pl -
2022-02-03 21:43:09 zmdc 1031 INF Starting pending process, zmc -m 11 zmdc.pl -
2022-02-03 21:43:09 zms_m6 4284 ERR Unable to load monitor id 6 for streaming zm_stream.cpp 45
2022-02-03 21:43:09 zms_m6 4284 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 21:43:09 zms_m6 4284 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
2022-02-03 21:43:08 zmdc 1031 ERR 'zmc -m 11' exited abnormally, exit status 255 zmdc.pl -
2022-02-03 21:43:08 zmc_m11 4282 ERR No monitors found zmc.cpp 212
2022-02-03 21:43:08 zmc_m11 4282 ERR Can't use query result: Unknown column 'Capturing' in 'field list' zm_monitor.cpp 939
2022-02-03 21:43:08 zmc_m11 4282 ERR Can't run query: Unknown column 'Capturing' in 'field list' zm_db.cpp 129
20
TheRoth - there may be a newer one.
1.37.11~20220203175409-focal
is working better for me.
- bkjaya1952
Yes !dougmccrary wrote: ↑Fri Feb 04, 2022 1:47 am TheRoth - there may be a newer one.
- bkjaya1952
For impish , focal , bionic as welldougmccrary wrote: ↑Fri Feb 04, 2022 1:47 am TheRoth - there may be a newer one.
Yes !
1.37.11~20220205.20-bullseye
Works very well ^^ Thanks
Same problem with the last update (maybe little different)...
1.37.11~20220214.143-bullseye
2022-02-14 20:48:26 zms_m9 1999725 WAR Using slow std functions zm_image.cpp 98
2022-02-14 20:48:26 zms_m8 1999721 WAR Using slow std functions zm_image.cpp 98
2022-02-14 20:48:26 zms_m7 1999720 WAR Using slow std functions zm_image.cpp 98
2022-02-14 20:48:26 zms_m2 1999719 WAR Using slow std functions
2022-02-14 20:47:57 zms_m1 1999680 ERR Can't open memory map file /dev/shm/zm.mmap.1: No such file or directory zm_monitor.cpp 798
2022-02-14 20:47:57 zms_m4 1999678 ERR Unable to connect to monitor id 4 for streaming zm_stream.cpp 59
2022-02-14 20:47:57 zms_m4 1999678 ERR Can't open memory map file /dev/shm/zm.mmap.4: No such file or directory zm_monitor.cpp 798
2022-02-14 20:47:57 zms_m11 1999676 ERR Unable to connect to monitor id 11 for streaming zm_stream.cpp 59
2022-02-14 20:47:57 zms_m11 1999676 ERR Can't open memory map file /dev/shm/zm.mmap.11: No such file or directory
Part of that is the fresh debug messages just dropped in to show up slow non-SSE functions.
