Page 1 of 1
zmfilter error
Posted: Mon Feb 21, 2022 9:24 am
by tommisgr
For some days now I keep getting the following errors on my syslog
zmfilter_7[8494]: ERR [Failure to load Object record for 158303: Reason: Lock wait timeout exceeded; try restarting transaction]
zmfilter_5[8470]: ERR [Src path /var/cache/zoneminder/events/20/2021-11-05/158298 does not exist.]
I have filter setup to clean my installation disk (SSD) by moving older events (5 days) and If disk over a limit (65%)
5 move to different disk after 5 days
7 move to different disk when disk over % limit full
As u can see from the log the move of files has been halted (files from 2021-11) still on ssd
The numbers of event keep rising the move of files is done and the target of the filter (scr path) are as expected emtpy since files have been moved to other disc
Is this a issue with mysql?
How can I resolve it?
Any pointer would be welcome.
Addidtionaly when I try to delete the records by running from web the list event and then deleting some I get
web_php[22664].ERR [10.10.10.11] [SQL-ERR 'SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction', statement was 'DELETE FROM Events WHERE Id = ?' params:158307] at /usr/share/zoneminder/www/includes/database.php line 161
When I change the filter to avoid the dates with missing events the filters run ok.
So the question is how to fix the mising event in the sql db
Re: zmfilter error
Posted: Tue Feb 22, 2022 11:29 am
by Magic919
Sounds like your DB can't keep up.
If you want to get the FS and DB back in sync, run zmaudit. I'd suggest not running the filters at all when doing so.
