Ubuntu Server 20.04 - clean install - all RAM used up?
herrjon
Post by herrjon »
I have a fresh install that I did in order to try and address the problem of a system running out of RAM.
This is a Dell 720, Dual Xeon, 24 core machine with 64GB of RAM.
The OS is Ubuntu Server 20.04
I have 10 channels of video, 7 of which are 4k resolution.
If I leave the analysis and decoding options on then the memory utilization for a given worker exceeds 26GB and soon all of the system memory is used until the OS kills the thread.
What should I do? I read somewhere that Zoneminder shouldn't ever try to use over 1/2 of the available system RAM but it is doing this. It is repeatable.
Thanks,
Jon
Re: Ubuntu Server 20.04 - clean install - all RAM used up?
Make sure you don’t have it saving JPEGs. Other than that it might be worth keeping keyframe interval short.
herrjon
Post by herrjon »
OK, I'll try changing settings... still doesn't seem right that this happens. Never had this problem before and I've been using ZM for over 10 years.
ZoneminderMemory1_2022-03-09 14-42-07.png (80.79 KiB) Viewed 696 times
Not sure any of that is relevant.
