1.36.12 - Ubuntu - Event Play Back issues
Ever since i installed 1.36.12 - i have observed an odd issue in the playback of events. It appears that the lower half of the screen is garbled a bit, whereas the top half is right as rein. It's not bad enough to not observe what's happening, but it is very annoying. This also ONLY occurs in color mode - when it flips to NIGHT CAM mode, the images are fine. Any ideas as to where a pertinent log may be ? Also, the standard camera (live) view is similarly fine.
- Snapshot of playback video
- ZMerror.png (415.64 KiB) Viewed 581 times
Re: 1.36.12 - Ubuntu - Event Play Back issues
What storage options are you using?
Camera resolution?
Camera resolution?
Known problem, actually due to a kernel change. I need to release 1.36.13 to fix it.
Excellent .. i can be patient .. thanks!
