Lots of Single Frame Events
xeroiv
Post by xeroiv »
I am just getting started with ZoneMinder and installed 1.36.11 on Debian. I am getting lot of single frame events when I set my monitors to mocord or record. It appears this issue has happened in the past. Is there any fix or perhaps something that I can check in my config? My settings are almost identical to the ones in this archived post.
viewtopic.php?p=110553#p110553
Edit: I don't know if this would be relevant, but I have the events by default storing on my NAS via a NFS connection. I followed a guide on these forums to replace the default storage location using Systemd.
https://wiki.zoneminder.com/Common_Issu ... ive_or_NAS
Re: Lots of Single Frame Events
I think you'll find that there is crashing happening. Check your logs.
xeroiv
Post by xeroiv »
That looks to be the case... now to figure out what it means is wrong.
2022-04-05 11:15:42 zmdc 12867 INF 'zmc -m 1' crashed, signal 8 zmdc.pl -
xeroiv
Post by xeroiv »
iconnor wrote: Tue Apr 05, 2022 1:11 pm I think you'll find that there is crashing happening. Check your logs.
So I have found through some testing that the ZMC crashes if I have the option to save JPEGs set to anything other than disabled. Is this something that I should submit as a github issue?
First you should update to 1.36.14.
Then if it's still a problem create the issue.
xeroiv
Post by xeroiv »
Thanks for the quick package for 1.36.14 on Debian 11. I updated and tried to enable save JPEG and checked my logs. I saw that ZMC immediately started crashing for the monitor that I enabled it on. I will work on submitting an issue to GitHub.
