Debian 11 Install Issues
Posted: Mon Apr 11, 2022 4:23 am
Tried using the official documentation and couldn't get zoneminder to load.
I've posted this to the Wiki under the Discussion page.
The Official Documentation should be updated. Install went really well once
the Database issue was figured out.
The main problem is during install no Database or User is installed.
This is what worked.
Fresh Install Debian 11
su
sudo usermod -a -G sudo <username>
sudo reboot
sudo apt update
sudo apt upgrade
sudo apt install mariadb-server
sudo /usr/bin/mysql_secure_installation
follow instructions:
Change to your requirements this works
current PW enter for none
socket auth Y
Change Root PW Y (enter your new root mysql Password)
Remove anon Y
Remove Remote Y
Remove test Y
Reload Priv Y
sudo apt install zoneminder
Enter mysql PW
mysql -u root -p -e "grant select,insert,update,delete,create,drop,alter,index,lock tables,alter routine,create routine,trigger,execute on zm.* to 'zmuser'@localhost identified by 'zmpass';"
Enter mysql PW
sudo chgrp -c www-data /etc/zm/zm.conf
sudo a2enconf zoneminder
sudo systemctl reload apache2
sudo systemctl enable zoneminder.service
sudo systemctl start zoneminder
Open a web browser window type [Your IP address/zm] without the [brackets]
Hope this helps others. Recommend updating the documentation for Debian 11
su
sudo reboot
sudo apt update
sudo apt upgrade
socket auth Y
Remove anon Y
Remove Remote Y
Remove test Y
Reload Priv Y
Enter mysql PW
Enter mysql PW
