I'm using ZoneMinder 1.36.14 on a Debian Bullseye box and I'm currently evaluating the Reolink RLC-410W. I'm using the dual-monitor setup where the substream monitor runs in Mocord mode and the mainstream monitor is linked in nodect mode. The setup is described here: https://www.reddit.com/r/reolinkcam/com ... inder_nvr/
This does, generally speaking, work. Except that when the monitors / zmc are restarted, or the camera looses connectivity momentarily or is restarted, it often takes a long time until capturing stabilizes. Until then, the log is spammed with these entries about every ten seconds:
"2022-04-16 21:57:05",zmc_m1,,6457,ERR,"Failed to capture image from monitor 1 Monitor-1 (1/1)",zmc.cpp,305
"2022-04-16 21:57:05",zmc_m1,,6457,INF,"Unable to read packet from stream 0: error -1094995529 ""Invalid data found when processing input"".",zm_ffmpeg_camera.cpp,226
"2022-04-16 21:56:43",zmc_m1,,6457,ERR,"Failed to capture image from monitor 1 Monitor-1 (1/1)",zmc.cpp,305
"2022-04-16 21:56:43",zmc_m1,,6457,INF,"Unable to read packet from stream 0: error -5 ""Input/output error"".",zm_ffmpeg_camera.cpp,226
"2022-04-16 21:56:43",zmc_m1,,6457,INF,"Monitor-1: 50 - Capturing at 3.77 fps, capturing bandwidth 59437bytes/sec",zm_monitor.cpp,1674
"2022-04-16 21:56:32",zmc_m1,,6457,ERR,"Failed to capture image from monitor 1 Monitor-1 (1/1)",zmc.cpp,305
"2022-04-16 21:56:32",zmc_m1,,6457,INF,"Unable to read packet from stream 0: error -5 ""Input/output error"".",zm_ffmpeg_camera.cpp,226
"2022-04-16 21:56:32",zmc_m1,,6457,INF,"Monitor-1: 10 - Capturing at 0.97 fps, capturing bandwidth 20116bytes/sec",zm_monitor.cpp,1674
"2022-04-16 21:56:21",zmc_m1,,6457,INF,"Starting Capture version 1.36.14",zmc.cpp,220
Sometimes this takes ~15 minutes and then it will work for many hours (presumably indefinitely). I've also seen this take an hour.
It's not a connectivity issue - this happens over wifi, as well as over a 1m patch cable. It also doesn't seem to be a load issue, as CPU load is very low (only the 640x360 substream is decoded and modected, the mainstream is passthrough). At first I thought this was a problem when using the substream and the mainstream simultaneously, but it still happens even if just one of them is used.
I've tried RTSP, and while this does not produce any logged errors, it produces massive amounts of repeated lines from the bottom of the frame up (I believe this is called smearing in Zoneminder parlance) and sometimes just blacked out macroblocks. This seems to be a common issue with RTSP on Reolink cameras.
FFMPEG version:
ffmpeg version 4.3.3-0+deb11u1 Copyright (c) 2000-2021 the FFmpeg developers built with gcc 10 (Debian 10.2.1-6) configuration: --prefix=/usr --extra-version=0+deb11u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100
Reolink RLC-410W - zmc often fails to start stream, but when it does, it's stable?
Re: Reolink RLC-410W - zmc often fails to start stream, but when it does, it's stable?
Debug log
Debug log for "invalid data found when processing input"
One complete run of zmc with Input/Output error message:
04/17/22 14:40:49.048899 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/626 [timeout in ffmpeg camera now 1650199249 - 1650199238 > 10]
04/17/22 14:40:49.048961 zmc_m2[18918].INF-zm_ffmpeg_camera.cpp/226 [Unable to read packet from stream 0: error -5 "Input/output error".]
04/17/22 14:40:49.049003 zmc_m2[18918].DB4-zm_monitor.cpp/2511 [Back from capture result=-1 image count 16]
04/17/22 14:40:49.049793 zmc_m2[18918].ERR-zmc.cpp/305 [Failed to capture image from monitor 2 Monitor-1low (1/1)]
04/17/22 14:44:18.070594 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 294542 * 1/1000=294.542000, dts: 294542, size: 49217, stream_index: 1, video flags: 0001, keyframe(1) pos: 157958, duration: 0]
04/17/22 14:44:18.070679 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 294310000 >= 294542000]
04/17/22 14:44:18.072322 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.074347 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.076151 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.078068 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.079629 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.081340 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.083259 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.085842 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.087723 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.089525 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.091209 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.093475 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.095619 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.097655 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.099589 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.101907 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.104449 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.106134 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.107889 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.109496 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.111188 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.112976 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.114674 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.116546 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.118278 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.119969 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:44:18.121795 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 7(SPS), nal_ref_idc: 3]
04/17/22 14:44:18.121828 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 8(PPS), nal_ref_idc: 3]
04/17/22 14:44:18.121877 zmc_m2[19084].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 5(IDR), nal_ref_idc: 3]
04/17/22 14:44:18.175165 zmc_m2[18918].WAR-zm_ffmpeg.cpp/69 [Packet mismatch 33848806 11 206800]
04/17/22 14:44:18.221539 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Skipping flv packet: type 0, size 568580, flags 0.]
04/17/22 14:44:29.045046 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/626 [timeout in ffmpeg camera now 1650199469 - 1650199458 > 10]
04/17/22 14:44:29.045090 zmc_m2[18918].WAR-zm_ffmpeg.cpp/69 [Unable to seek to the next packet]
04/17/22 14:44:29.045145 zmc_m2[18918].INF-zm_ffmpeg_camera.cpp/226 [Unable to read packet from stream 0: error -1094995529 "Invalid data found when processing input".]
04/17/22 14:44:29.048048 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Statistics: 568273 bytes read, 0 seeks]
04/17/22 14:44:29.048075 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Deleting stream...]
04/17/22 14:40:27.545130 zmc_m2[18918].INF-zm_ffmpeg.cpp/84 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
04/17/22 14:40:27.584770 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/183 [Priming capture from rtmp://xxx.xxx.xxx.xxx/bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=]
04/17/22 14:40:27.584802 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/307 [Calling avformat_open_input for rtmp://xxx.xxx.xxx.xxx/bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=]
04/17/22 14:40:27.584897 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Opening 'rtmp://xxx.xxx.xxx.xxx/bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=' for reading]
04/17/22 14:40:27.584927 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [No default whitelist set]
04/17/22 14:40:27.584959 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [No default whitelist set]
04/17/22 14:40:27.585012 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Original list of addresses:]
04/17/22 14:40:27.585035 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Address xxx.xxx.xxx.xxx port 1935]
04/17/22 14:40:27.585075 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Interleaved list of addresses:]
04/17/22 14:40:27.585091 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Address xxx.xxx.xxx.xxx port 1935]
04/17/22 14:40:27.585103 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Starting connection attempt to xxx.xxx.xxx.xxx port 1935]
04/17/22 14:40:27.631090 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Successfully connected to xxx.xxx.xxx.xxx port 1935]
04/17/22 14:40:27.631140 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Handshaking...]
04/17/22 14:40:28.619293 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Type answer 3]
04/17/22 14:40:28.619348 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Server version 13.14.10.13]
04/17/22 14:40:28.619546 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Proto = rtmp, path = /bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=, app = bcs, fname = channel0_sub.bcs?channel=0&stream=1&user=admin&password=]
04/17/22 14:40:28.674283 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Window acknowledgement size = 5000000]
04/17/22 14:40:28.676951 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Max sent, unacked = 5000000]
04/17/22 14:40:28.715266 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [New incoming chunk size = 4096]
04/17/22 14:40:28.715357 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Creating stream...]
04/17/22 14:40:28.815952 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Sending play command for 'channel0_sub.bcs?channel=0&stream=1&user=admin&password=']
04/17/22 14:40:33.327715 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Format flv probed with size=2048 and score=100]
04/17/22 14:40:33.328927 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/341 [Finding stream info]
04/17/22 14:40:33.328989 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Before avformat_find_stream_info() pos: 13 bytes read:33087 seeks:0 nb_streams:0]
04/17/22 14:40:33.329023 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Unknown type |RtmpSampleAccess]
04/17/22 14:40:33.329503 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 7(SPS), nal_ref_idc: 3]
04/17/22 14:40:33.329530 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 8(PPS), nal_ref_idc: 3]
04/17/22 14:40:33.329944 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 7(SPS), nal_ref_idc: 3]
04/17/22 14:40:33.329979 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 8(PPS), nal_ref_idc: 3]
04/17/22 14:40:33.330298 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 5(IDR), nal_ref_idc: 3]
04/17/22 14:40:33.330336 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Format yuv420p chosen by get_format().]
04/17/22 14:40:33.330353 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Reinit context to 640x352, pix_fmt: yuv420p]
04/17/22 14:40:33.365395 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:35.177253 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:35.182151 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:35.185139 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:35.190071 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:35.192843 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.099400 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/626 [timeout in ffmpeg camera now 1650199238 - 1650199227 > 10]
04/17/22 14:40:38.099445 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/626 [timeout in ffmpeg camera now 1650199238 - 1650199227 > 10]
04/17/22 14:40:38.099532 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 6.250000 0.019952]
04/17/22 14:40:38.099555 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 6.333333 0.018526]
04/17/22 14:40:38.099570 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 6.333333 0.018526]
04/17/22 14:40:38.099598 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 23.666667 0.019229]
04/17/22 14:40:38.099620 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 29.833333 0.013332]
04/17/22 14:40:38.099635 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 29.833333 0.013332]
04/17/22 14:40:38.099651 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 29.916667 0.003443]
04/17/22 14:40:38.099667 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 29.916667 0.003443]
04/17/22 14:40:38.099683 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 30.000000 0.000060]
04/17/22 14:40:38.099700 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 30.000000 0.000060]
04/17/22 14:40:38.099717 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 60.000000 0.000238]
04/17/22 14:40:38.099733 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 60.000000 0.000238]
04/17/22 14:40:38.099750 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 120.000000 0.000953]
04/17/22 14:40:38.099767 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 120.000000 0.000953]
04/17/22 14:40:38.099783 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 240.000000 0.003812]
04/17/22 14:40:38.099799 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 240.000000 0.003812]
04/17/22 14:40:38.099815 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 29.970030 0.000527]
04/17/22 14:40:38.099830 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 29.970030 0.000527]
04/17/22 14:40:38.099858 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 59.940060 0.002110]
04/17/22 14:40:38.099873 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [rfps: 59.940060 0.002110]
04/17/22 14:40:38.099892 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Ignoring outlier non primary stream starttime 0.000000]
04/17/22 14:40:38.099909 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Ignoring outlier non primary stream starttime 0.000000]
04/17/22 14:40:38.100204 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [After avformat_find_stream_info() pos: 125165 bytes read:125165 seeks:0 frames:55]
04/17/22 14:40:38.100224 zmc_m2[18918].DB2-zm_ffmpeg.cpp/453 [Not a video type 2 != 0]
04/17/22 14:40:38.100233 zmc_m2[18918].DB2-zm_ffmpeg.cpp/453 [Not a video type 1 != 0]
04/17/22 14:40:38.100240 zmc_m2[18918].DB3-zm_ffmpeg_camera.cpp/383 [Found video stream at index 1, audio stream at index 2]
04/17/22 14:40:38.100290 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/395 [Failed to find decoder (h264_mmal)]
04/17/22 14:40:38.100316 zmc_m2[18918].DB1-zm_ffmpeg.cpp/280 [Dumping stream index i(1) index(0)]
04/17/22 14:40:38.100326 zmc_m2[18918].DB1-zm_ffmpeg.cpp/290 [ Stream #0:1]
04/17/22 14:40:38.100333 zmc_m2[18918].DB1-zm_ffmpeg.cpp/298 [frame_size:0 stream timebase: 1/1000]
04/17/22 14:40:38.100342 zmc_m2[18918].DB1-zm_ffmpeg.cpp/304 [codec: h264 video]
04/17/22 14:40:38.100354 zmc_m2[18918].DB1-zm_ffmpeg.cpp/232 [1k stream tb numerator]
04/17/22 14:40:38.100434 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 7(SPS), nal_ref_idc: 3]
04/17/22 14:40:38.100462 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 8(PPS), nal_ref_idc: 3]
04/17/22 14:40:38.100601 zmc_m2[18918].DB1-zm_ffmpeg.cpp/254 [Dumping codec_context codec_type(0 video) codec_id(27 h264) width(640) height(352) timebase(0/2) format(yuv420p) gop_size 12 max_b_frames 0 me_cmp 0 me_range 0 qmin 2 qmax 31]
04/17/22 14:40:38.100645 zmc_m2[18918].DB1-zm_ffmpeg.cpp/280 [Dumping stream index i(2) index(0)]
04/17/22 14:40:38.100661 zmc_m2[18918].DB1-zm_ffmpeg.cpp/290 [ Stream #0:2]
04/17/22 14:40:38.100675 zmc_m2[18918].DB1-zm_ffmpeg.cpp/298 [frame_size:1024 stream timebase: 1/1000]
04/17/22 14:40:38.100689 zmc_m2[18918].DB1-zm_ffmpeg.cpp/304 [codec: aac audio]
04/17/22 14:40:38.100701 zmc_m2[18918].DB1-zm_ffmpeg.cpp/337 [profile 1 channels 1 sample_rate 16000]
04/17/22 14:40:38.128989 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 0 >= 0]
04/17/22 14:40:38.129007 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 0 * 1/1000=0.000000, dts: 0, size: 24, stream_index: 0, data flags: 0001, keyframe(1) pos: 13, duration: 0]
04/17/22 14:40:38.129080 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 0 >= 0]
04/17/22 14:40:38.129094 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 70976 * 1/1000=70.976000, dts: 70976, size: 49338, stream_index: 1, video flags: 0001, keyframe(1) pos: 319, duration: 0]
04/17/22 14:40:38.129272 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 0 >= 70976000]
04/17/22 14:40:38.129293 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71004 * 1/1000=71.004000, dts: 71004, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 49696, duration: 64]
04/17/22 14:40:38.129463 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71004000 >= 70976000]
04/17/22 14:40:38.129480 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71068 * 1/1000=71.068000, dts: 71068, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 50225, duration: 64]
04/17/22 14:40:38.129540 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71068000 >= 70976000]
04/17/22 14:40:38.129553 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71132 * 1/1000=71.132000, dts: 71132, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 50754, duration: 64]
04/17/22 14:40:38.129609 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71132000 >= 70976000]
04/17/22 14:40:38.129622 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71109 * 1/1000=71.109000, dts: 71109, size: 2092, stream_index: 1, video flags: 0000, keyframe(0) pos: 51283, duration: 0]
04/17/22 14:40:38.129773 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71132000 >= 71109000]
04/17/22 14:40:38.129787 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71196 * 1/1000=71.196000, dts: 71196, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 53395, duration: 64]
04/17/22 14:40:38.129845 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71196000 >= 71109000]
04/17/22 14:40:38.129867 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71260 * 1/1000=71.260000, dts: 71260, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 53924, duration: 64]
04/17/22 14:40:38.129924 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71260000 >= 71109000]
04/17/22 14:40:38.129938 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71243 * 1/1000=71.243000, dts: 71243, size: 2041, stream_index: 1, video flags: 0000, keyframe(0) pos: 54453, duration: 0]
04/17/22 14:40:38.130026 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71260000 >= 71243000]
04/17/22 14:40:38.130043 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71324 * 1/1000=71.324000, dts: 71324, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 56514, duration: 64]
04/17/22 14:40:38.130109 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71324000 >= 71243000]
04/17/22 14:40:38.130124 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 5(IDR), nal_ref_idc: 3]
04/17/22 14:40:38.130164 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [Format yuv420p chosen by get_format().]
04/17/22 14:40:38.130180 zmc_m2[18981].DB2-zm_ffmpeg.cpp/69 [Reinit context to 640x352, pix_fmt: yuv420p]
04/17/22 14:40:38.130597 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71388 * 1/1000=71.388000, dts: 71388, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 57043, duration: 64]
04/17/22 14:40:38.130691 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71388000 >= 71243000]
04/17/22 14:40:38.130706 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71376 * 1/1000=71.376000, dts: 71376, size: 3295, stream_index: 1, video flags: 0000, keyframe(0) pos: 57572, duration: 0]
04/17/22 14:40:38.130846 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71388000 >= 71376000]
04/17/22 14:40:38.130860 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71452 * 1/1000=71.452000, dts: 71452, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 60887, duration: 64]
04/17/22 14:40:38.130919 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71452000 >= 71376000]
04/17/22 14:40:38.130933 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71516 * 1/1000=71.516000, dts: 71516, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 61416, duration: 64]
04/17/22 14:40:38.130991 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71516000 >= 71376000]
04/17/22 14:40:38.131004 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71543 * 1/1000=71.543000, dts: 71543, size: 3379, stream_index: 1, video flags: 0000, keyframe(0) pos: 61945, duration: 0]
04/17/22 14:40:38.131073 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71516000 >= 71543000]
04/17/22 14:40:38.131087 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71580 * 1/1000=71.580000, dts: 71580, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 65344, duration: 64]
04/17/22 14:40:38.131146 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71580000 >= 71543000]
04/17/22 14:40:38.131160 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71644 * 1/1000=71.644000, dts: 71644, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 65873, duration: 64]
04/17/22 14:40:38.131218 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71644000 >= 71543000]
04/17/22 14:40:38.131231 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71708 * 1/1000=71.708000, dts: 71708, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 66402, duration: 64]
04/17/22 14:40:38.131316 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71708000 >= 71543000]
04/17/22 14:40:38.131330 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71772 * 1/1000=71.772000, dts: 71772, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 66931, duration: 64]
04/17/22 14:40:38.131474 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71772000 >= 71543000]
04/17/22 14:40:38.131489 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71709 * 1/1000=71.709000, dts: 71709, size: 3715, stream_index: 1, video flags: 0000, keyframe(0) pos: 67460, duration: 0]
04/17/22 14:40:38.131560 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71772000 >= 71709000]
04/17/22 14:40:38.131574 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71836 * 1/1000=71.836000, dts: 71836, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 71195, duration: 64]
04/17/22 14:40:38.131633 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71836000 >= 71709000]
04/17/22 14:40:38.131646 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71876 * 1/1000=71.876000, dts: 71876, size: 4380, stream_index: 1, video flags: 0000, keyframe(0) pos: 71724, duration: 0]
04/17/22 14:40:38.131720 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71836000 >= 71876000]
04/17/22 14:40:38.131786 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71900 * 1/1000=71.900000, dts: 71900, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 76124, duration: 64]
04/17/22 14:40:38.131868 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71900000 >= 71876000]
04/17/22 14:40:38.131883 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 71964 * 1/1000=71.964000, dts: 71964, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 76653, duration: 64]
04/17/22 14:40:38.131941 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 71964000 >= 71876000]
04/17/22 14:40:38.131955 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72028 * 1/1000=72.028000, dts: 72028, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 77182, duration: 64]
04/17/22 14:40:38.132014 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72028000 >= 71876000]
04/17/22 14:40:38.132029 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72092 * 1/1000=72.092000, dts: 72092, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 77711, duration: 64]
04/17/22 14:40:38.132087 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72092000 >= 71876000]
04/17/22 14:40:38.132100 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72076 * 1/1000=72.076000, dts: 72076, size: 4717, stream_index: 1, video flags: 0000, keyframe(0) pos: 78240, duration: 0]
04/17/22 14:40:38.132280 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72092000 >= 72076000]
04/17/22 14:40:38.132296 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72156 * 1/1000=72.156000, dts: 72156, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 82977, duration: 64]
04/17/22 14:40:38.132364 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72156000 >= 72076000]
04/17/22 14:40:38.132380 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72220 * 1/1000=72.220000, dts: 72220, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 83506, duration: 64]
04/17/22 14:40:38.132460 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72220000 >= 72076000]
04/17/22 14:40:38.132477 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72209 * 1/1000=72.209000, dts: 72209, size: 3681, stream_index: 1, video flags: 0000, keyframe(0) pos: 84035, duration: 0]
04/17/22 14:40:38.132648 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72220000 >= 72209000]
04/17/22 14:40:38.132667 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72284 * 1/1000=72.284000, dts: 72284, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 87736, duration: 64]
04/17/22 14:40:38.132792 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72284000 >= 72209000]
04/17/22 14:40:38.132808 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72348 * 1/1000=72.348000, dts: 72348, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 88265, duration: 64]
04/17/22 14:40:38.132868 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72348000 >= 72209000]
04/17/22 14:40:38.132881 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72343 * 1/1000=72.343000, dts: 72343, size: 3405, stream_index: 1, video flags: 0000, keyframe(0) pos: 88794, duration: 0]
04/17/22 14:40:38.133057 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72348000 >= 72343000]
04/17/22 14:40:38.133075 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72412 * 1/1000=72.412000, dts: 72412, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 92219, duration: 64]
04/17/22 14:40:38.133135 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72412000 >= 72343000]
04/17/22 14:40:38.133149 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72476 * 1/1000=72.476000, dts: 72476, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 92748, duration: 64]
04/17/22 14:40:38.133208 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72476000 >= 72343000]
04/17/22 14:40:38.133222 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72476 * 1/1000=72.476000, dts: 72476, size: 3227, stream_index: 1, video flags: 0000, keyframe(0) pos: 93277, duration: 0]
04/17/22 14:40:38.133295 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72476000 >= 72476000]
04/17/22 14:40:38.133311 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72540 * 1/1000=72.540000, dts: 72540, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 96524, duration: 64]
04/17/22 14:40:38.133379 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72540000 >= 72476000]
04/17/22 14:40:38.133396 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72604 * 1/1000=72.604000, dts: 72604, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 97053, duration: 64]
04/17/22 14:40:38.133467 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72604000 >= 72476000]
04/17/22 14:40:38.133489 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72643 * 1/1000=72.643000, dts: 72643, size: 4502, stream_index: 1, video flags: 0000, keyframe(0) pos: 97582, duration: 0]
04/17/22 14:40:38.133670 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72604000 >= 72643000]
04/17/22 14:40:38.133684 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72668 * 1/1000=72.668000, dts: 72668, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 102104, duration: 64]
04/17/22 14:40:38.133745 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72668000 >= 72643000]
04/17/22 14:40:38.133759 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72732 * 1/1000=72.732000, dts: 72732, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 102633, duration: 64]
04/17/22 14:40:38.133817 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72732000 >= 72643000]
04/17/22 14:40:38.133830 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72796 * 1/1000=72.796000, dts: 72796, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 103162, duration: 64]
04/17/22 14:40:38.133888 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72796000 >= 72643000]
04/17/22 14:40:38.133901 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72809 * 1/1000=72.809000, dts: 72809, size: 4031, stream_index: 1, video flags: 0000, keyframe(0) pos: 103691, duration: 0]
04/17/22 14:40:38.133970 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72796000 >= 72809000]
04/17/22 14:40:38.133983 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72860 * 1/1000=72.860000, dts: 72860, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 107742, duration: 64]
04/17/22 14:40:38.134050 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72860000 >= 72809000]
04/17/22 14:40:38.134063 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72924 * 1/1000=72.924000, dts: 72924, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 108271, duration: 64]
04/17/22 14:40:38.134123 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72924000 >= 72809000]
04/17/22 14:40:38.134136 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72988 * 1/1000=72.988000, dts: 72988, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 108800, duration: 64]
04/17/22 14:40:38.134201 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72988000 >= 72809000]
04/17/22 14:40:38.134217 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 72976 * 1/1000=72.976000, dts: 72976, size: 4246, stream_index: 1, video flags: 0000, keyframe(0) pos: 109329, duration: 0]
04/17/22 14:40:38.134367 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 72988000 >= 72976000]
04/17/22 14:40:38.134382 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73052 * 1/1000=73.052000, dts: 73052, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 113595, duration: 64]
04/17/22 14:40:38.134519 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73052000 >= 72976000]
04/17/22 14:40:38.134535 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73116 * 1/1000=73.116000, dts: 73116, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 114124, duration: 64]
04/17/22 14:40:38.134619 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73116000 >= 72976000]
04/17/22 14:40:38.134633 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73180 * 1/1000=73.180000, dts: 73180, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 114653, duration: 64]
04/17/22 14:40:38.135195 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73180000 >= 72976000]
04/17/22 14:40:38.135210 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73176 * 1/1000=73.176000, dts: 73176, size: 4541, stream_index: 1, video flags: 0000, keyframe(0) pos: 115182, duration: 0]
04/17/22 14:40:38.135290 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73180000 >= 73176000]
04/17/22 14:40:38.135304 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73244 * 1/1000=73.244000, dts: 73244, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 119743, duration: 64]
04/17/22 14:40:38.135429 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73244000 >= 73176000]
04/17/22 14:40:38.135442 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73308 * 1/1000=73.308000, dts: 73308, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 120272, duration: 64]
04/17/22 14:40:38.135501 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73308000 >= 73176000]
04/17/22 14:40:38.135527 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73372 * 1/1000=73.372000, dts: 73372, size: 512, stream_index: 2, audio flags: 0001, keyframe(1) pos: 120801, duration: 64]
04/17/22 14:40:38.135676 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73372000 >= 73176000]
04/17/22 14:40:38.135689 zmc_m2[18918].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 73309 * 1/1000=73.309000, dts: 73309, size: 3815, stream_index: 1, video flags: 0000, keyframe(0) pos: 121330, duration: 0]
04/17/22 14:40:38.135762 zmc_m2[18918].DB4-zm_ffmpeg_camera.cpp/213 [Using video input because 73372000 >= 73309000]
04/17/22 14:40:38.139317 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.142068 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.145150 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.148076 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.150169 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.152124 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.154427 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.156797 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.159020 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.161337 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.163336 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.165560 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.167569 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.169857 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:38.172148 zmc_m2[18981].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 1]
04/17/22 14:40:49.051570 zmc_m2[18918].DB2-zm_ffmpeg.cpp/69 [Statistics: 125165 bytes read, 0 seeks]
04/17/22 14:40:49.051603 zmc_m2[18918].DB3-zm_ffmpeg.cpp/69 [Deleting stream...]
04/17/22 14:40:49.051622 zmc_m2[18918].DB1-zm_ffmpeg_camera.cpp/626 [timeout in ffmpeg camera now 1650199249 - 1650199238 > 10]
Well, between the unreliability of the streams and the poor wifi implementation (the RLC-410W does *not* support 2.4 GHz wifi, severely limiting the range, and despite being marketed as a dual-band camera) these will go. Oh, and you can't even set the timezone in the firmware. I guess everyone is in US/Pacific... the fact that the firmware version on the bought (and sealed) cameras is newer than what they offer for download on their website also does not inspire trust.
Looks like a camera problem, rather than ZM. Reads as though it's struggling to get a keyframe to get started.
I recently picked up a RLC-410 (non W) I have different, yet similar issues with it, I'm guessing that model of camera is well, junk.
To put it simply: She's about as stable as Marv's contraption for getting out of the basement in Home Alone 2!
That being said, I take a care of a farm property outside of town and have a couple Reolink cameras of a different model out there, while I'm running them stand-alone with a microSD card, they have been trouble free.
