My old SV3C cameras no longer work
Posted: Thu Apr 21, 2022 2:05 am
I am not sure exactly what happened.
I had to change routers, and it forced me to figure out why zoneminder quit working.
Finally figured out that I had set my old SV3C cameras to be fixed addresses, and when I changed routers zoneminder of course couldn't find them.
Eventually got that sorted out, but still had all sorts of troubles getting zoneminder console to even see them.
As part of the process, I started over with version 1.36.14. Not sure if that has anything to do with all the other changes I've made.
When I finally got the reinstall done, and with all sorts of fooling around, the console can now finally see the cameras, but the picture from the cameras doesn't reach zone minder.
Here's an example of the address I used, which worked (on one of my two cameras) on VLC, but not ZoneMinder 1.36.14.
rtsp://name:password@192.168.1.126:554/stream0
Any thoughts on any changes I can make with the myriad of choices on the settings for....
1) SV-801POE-1080P-L (doesn't work with VLC)
2) SV-801POE-1080P-A (does work with VLC)
Or, are there any more recent cameras that are EASY To configure for ZoneMinder?
I've spent a LOT of time on all of this so far, and it may just be easier to start with new highly recommended cameras that are easy to set up with ZoneMinder.
THANKS !
THANKS !
