[Solved] Storage diskspace incorrect
trumee
Post by trumee »
I have add a 4TB disk to Zoneminder sysem. It shows up correctly at the OS level
# df -h
Filesystem                     Size  Used Avail Use% Mounted on
/dev/sdm1                      3.6T   74M  3.4T   1% /mnt/WCC130908716
However, ZM shows that only 186GB is available.
Any idea what could be the issue?
Andyrh
Re: Storage diskspace incorrect
Post by Andyrh »
You are reading it backwards. That is used, not free space.
Used/Total
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
trumee
Post by trumee »
ah, i see. Thanks!
