FOSCAM VZ4 4MP Outdoor Security WiFi Camera. On my phone the Foscam App works fine, good image. Laptop/Desktop: http://[user:pw]IP:88 displays a page with a login/pw page and instructions to download an App. When I click I get a foscam 404 page. I've also tried to add it to ZM - no joy either. And so far support @ FC is no joy.
Suggestions please.
tks
Foscam VZ4 PTZ outdoor
Re: Foscam VZ4 PTZ outdoor
I'm able to get VLC to display using
rtsp://fc1:43fce4321x@192.168.0.71:88/videoMain
but not is ZM
but not is ZM
:88 is usually http, tried that instead of rtsp?
I've tried with and without the "88" and http/rtsp - no joy. Could be the version of ZM, it's older on an older box (sleeping dog...).
Oh, and I did hear from Foscam - "You need to pay Bill Gates several hundred dollars in tribute to use our product".
You have log errors from zoneminder?
Or info logs at least depending on your log settings?
When I hit Save on the config window.
05/09/2022 10:44:37.633373 zmdc[3387].INF [Command 'zmc -m 23' removed from pending list at 22/05/09 10:44:37]
05/09/2022 10:44:37.903322 zmdc[3387].INF ['zmc -m 23' starting at 22/05/09 10:44:37, pid = 22717]
05/09/2022 10:44:38.002298 zmdc[3387].ERR ['zmc -m 23' exited abnormally, exit status 255]
05/09/2022 10:44:38.002986 zmdc[3387].INF [Starting pending process, zmc -m 23]
05/09/2022 10:44:38.005311 zmdc[3387].INF ['zmc -m 23' starting at 22/05/09 10:44:38, pid = 22721]
05/09/2022 10:44:38.093553 zmdc[3387].ERR ['zmc -m 23' exited abnormally, exit status 255]
05/09/2022 10:44:38.264569 zmdc[3387].WAR [Can't find process with command of 'zma -m 23']
05/09/2022 10:44:43.019722 zmdc[3387].INF [Starting pending process, zmc -m 23]
I take it that error sequence loops forever?
hmm what version? Does it have General -> Source Type = Ffmpeg?Could be the version of ZM, it's older on an older box
Older system v1.24.2. FFMPEG has been installed for some time and has been used before.
PATH_CAMBOZOLA Web path to (optional) cambozola java streaming client (?) vs,npxp;s/kst
RELOAD_CAMBOZOLA After how many seconds should Cambobozola be reloaded in live view (?) 0
OPT_FFMPEG Is the ffmpeg video encoder/decoder installedisr (?) ck
PATH_FFMPEG Path to (optional) ffmpeg mpeg encoder (?) /usr/bin/ffmpeg
FFMPEG_INPUT_OPTIONS Additional input options to ffmpeg (?)
FFMPEG_OUTPUT_OPTIONS Additional output options to ffmpeg (?) -r 25
FFMPEG_FORMATS Formats to allow for ffmpeg video generation (?) mpg mpeg wmv asf avi* mov swf 3gp**
OPT_NETPBM Are the (optional) Netpbm utilities installed (?) ck
PATH_NETPBM Path to (optional) Netpbm utilities (?) /usr/bin
Cambozola is unchecked, I suppose.
I can only guess maybe you have an older version of ffmpeg - I have 7 something. But if that's the case upgrading it may break everything.
Sorry, I give up.
Sorry, I give up.
