I am running Zoneminder v1.36.12 on a Core2Duo E6550 2.33Ghz. I have 2 cameras set to 4 FPS and using the low res streams (640x360). They are both set to Monitor (no mocord or modect yet).
The issue I have is that in Montage view, the cams are fine. They are working as expected and the videos are updating smoothly. But when the cameras are viewed individually (http://IP_ADDRESS/zm/index.php?view=watch&mid=X), the video is updating only every 5-10 seconds.
Is there some setting that makes it do this when viewed individually vs. in the montage? Thanks for any help/advice.
