[SOLVED] Debian Bullseye repo confusion
sherminator
Post by sherminator »
Hi there,
we're currently on ZoneMinder 1.36.12 on a Debian Bullseye and want to update to... i think 1.36.14 is latest for amd64 systems. We use
deb https://zmrepo.zoneminder.com/debian/release-1.36/bullseye/ /
in our repo file.
apt update
works fine and shows zoneminder and zoneminder-doc ready to update. When doing
apt upgrade
apt tells us
Err:1 https://zmrepo.zoneminder.com/debian/release-1.36/bullseye  zoneminder 1.36.14-bullseye1
  404  Not Found [IP: 158.69.226.113 443]
Err:2 https://zmrepo.zoneminder.com/debian/release-1.36/bullseye  zoneminder-doc 1.36.15-bullseye1
E: Failed to fetch https://zmrepo.zoneminder.com/debian/release-1.36/bullseye/bullseye/zoneminder_1.36.14-bullseye1_amd64.deb  404  Not Found [IP: 158.69.226.113 443]
E: Failed to fetch https://zmrepo.zoneminder.com/debian/release-1.36/bullseye/bullseye/zoneminder-doc_1.36.15-bullseye1_all.deb  404  Not Found [IP: 158.69.226.113 443]
Is this a mistake in your repos or do we miss something at our site?
Thanks for your support and greets
Stephan
Re: Debian Bullseye repo confusion
Too many /bullseye
sherminator
Magic919 wrote: Mon May 23, 2022 12:38 pm Too many /bullseye
Hey,
thanks for your reply!
I can see that too, but how can I fix it? If I remove "bullseye" from the URL in the repo file, apt update gives me
Err:5 https://zmrepo.zoneminder.com/debian/release-1.36  Release
Reading package lists... Done
E: The repository 'https://zmrepo.zoneminder.com/debian/release-1.36  Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I don’t use Debian, but your url differs from in this doc https://zoneminder.readthedocs.io/en/la ... ebian.html
sherminator
Magic919 wrote: Mon May 23, 2022 2:21 pm I don’t use Debian, but your url differs from in this doc https://zoneminder.readthedocs.io/en/la ... ebian.html
yeah, your're right! The correct repo entry looks like this
deb https://zmrepo.zoneminder.com/debian/release-1.36 bullseye/
no idea when and how this mistake sneaked into our file.
Sorry for that!
Greets
Stephan
