Page 1 of 1
Update Problem 1..36.15 debian 4.19.0-20-amd64
Posted: Thu May 26, 2022 6:24 am
by gersan89
Hi, Kindly ask for support. Many thanks
Initiating database upgrade to version 1.36.15 from version 1.36.14
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file in /var/tmp/zm if you have a lot of events.
Press 'y' for a backup or 'n' to continue : y
Creating backup to /var/tmp/zm/zm-1.36.14.dump. This may take several minutes.
Database successfully backed up to /var/tmp/zm/zm-1.36.14.dump, proceeding to upgrade.
Upgrading database to version 1.36.15
Loading config from DB 221 entries
Saving config to DB 221 entries
DBD::mysql::st execute failed: Unknown column 'System' in 'field list' at /usr/share/perl5/ZoneMinder/Config.pm line 243, <STDIN> line 1.
Can't execute when updating config entry ZM_SKIN_DEFAULT: Unknown column 'System' in 'field list' at /usr/bin/zmupdate.pl line 453.
Re: Update Problem 1..36.15 debian 4.19.0-20-amd64
Posted: Thu May 26, 2022 3:49 pm
by Magic919
From the Slack channel
new packages are building. for now you can do mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.36.16.sql
Posted: Thu May 26, 2022 8:50 pm
by gersan89
Thank you very much! It runs!
Posted: Fri May 27, 2022 12:00 pm
by Magic919
Good news!
