I'm adding a few cameras to my network and decided to upgrade my old dual core 2.13 2gig server with a quad core 2.67 8gig. The old one was happy to run three cameras and was ok with a couple more. The new one is running Ubuntu 20 and runs great on two cameras with a load of around 1.3. As soon as I add a third camera, load spikes to 20 and the system becomes unusable. I can't even start a ssh session. They only way to recover is a hard reboot. Checking the memory usage just now with two cameras it's setting at 91%. The configuration is identical to the old server.
Jun 14 10:51:59 zm3 systemd[1]: Finished Ubuntu Advantage Timer for running repeated jobs.
Jun 14 10:52:51 zm3 zmc_m6[5786]: ERR [zmc_m6] [Can't mkdir /mnt/mnt126/6: Permission denied]
Jun 14 10:52:53 zm3 zmc_m6[5786]: WAR [zmc_m6] [Monitor dimensions are 640x480 but camera is sending 2592x1944]
Jun 14 10:52:54 zm3 zmc_m6[5786]: ERR [zmc_m6] [Can't mkdir /mnt/mnt126/6: Permission denied]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [Failed creating event dir at /mnt/mnt126]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [non increasing dts, fixing. our dts -30000 stream 0 last_dts 0]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [pkt.dts(0) must be <= pkt.pts(-30000).Decompression must happen before presentation.]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [non increasing dts, fixing. our dts -24000 stream 0 last_dts 0]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [pkt.dts(0) must be <= pkt.pts(-24000).Decompression must happen before presentation.]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [non increasing dts, fixing. our dts -18000 stream 0 last_dts 0]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [pkt.dts(0) must be <= pkt.pts(-18000).Decompression must happen before presentation.]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [non increasing dts, fixing. our dts -12000 stream 0 last_dts 0]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [pkt.dts(0) must be <= pkt.pts(-12000).Decompression must happen before presentation.]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [non increasing dts, fixing. our dts -6000 stream 0 last_dts 0]
Jun 14 10:52:54 zm3 zmc_m6[5786]: WAR [zmc_m6] [pkt.dts(0) must be <= pkt.pts(-6000).Decompression must happen before presentation.]
Jun 14 10:55:30 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 135 seconds behind capture.]
Jun 14 10:55:32 zm3 kernel: [ 766.388466] 8139too 0000:06:04.0 enp6s4: link down
Jun 14 10:55:34 zm3 systemd-networkd[767]: enp6s4: Lost carrier
Jun 14 10:55:35 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 142 seconds behind capture.]
Jun 14 10:55:39 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 146 seconds behind capture.]
Jun 14 10:55:44 zm3 systemd[1]: Started Session 3 of user root.
Jun 14 10:55:46 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 153 seconds behind capture.]
Jun 14 10:55:47 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 154 seconds behind capture.]
Jun 14 10:55:47 zm3 zmc_m1[3170]: message repeated 14 times: [ WAR [zmc_m1] [Decoding is not keeping up. We are 154 seconds behind capture.]]
Jun 14 10:55:47 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 153 seconds behind capture.]
Jun 14 10:55:47 zm3 zmc_m1[3170]: message repeated 22 times: [ WAR [zmc_m1] [Decoding is not keeping up. We are 153 seconds behind capture.]]
Jun 14 10:55:48 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 154 seconds behind capture.]
Jun 14 10:55:48 zm3 zmc_m1[3170]: message repeated 9 times: [ WAR [zmc_m1] [Decoding is not keeping up. We are 154 seconds behind capture.]]
Jun 14 10:55:50 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 156 seconds behind capture.]
Jun 14 10:55:52 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 158 seconds behind capture.]
Jun 14 10:55:53 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 159 seconds behind capture.]
Jun 14 10:55:53 zm3 zmc_m1[3170]: message repeated 2 times: [ WAR [zmc_m1] [Decoding is not keeping up. We are 159 seconds behind capture.]]
Jun 14 10:55:54 zm3 zmc_m6[5786]: ERR [zmc_m6] [Failed to capture image from monitor 6 Monitor-4 (1/1)]
Jun 14 10:55:54 zm3 zmc_m1[3170]: ERR [zmc_m1] [Failed to capture image from monitor 1 Living Room (1/1)]
Jun 14 10:55:54 zm3 zmc_m4[3204]: ERR [zmc_m4] [Failed to capture image from monitor 4 Bedroom (1/1)]
Jun 14 10:55:55 zm3 zmc_m1[3170]: WAR [zmc_m1] [Decoding is not keeping up. We are 161 seconds behind capture.]
Jun 14 10:55:59 zm3 zmwatch[1233]: WAR [Restarting capture daemon for Bedroom, time since last capture 132 seconds (1655229356-1655229224)]
Jun 14 10:56:02 zm3 zmc_m4[3204]: WAR [zmc_m4] [Decoding is not keeping up. We are 138 seconds behind capture.]
Jun 14 10:56:08 zm3 zmc_m6[5786]: ERR [zmc_m6] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:56:11 zm3 zmc_m4[3204]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Interrupted system call]
Jun 14 10:56:11 zm3 zmc_m4[3204]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:56:11 zm3 zmc_m6[5786]: ERR [zmc_m6] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Interrupted system call]
Jun 14 10:56:11 zm3 zmc_m6[5786]: ERR [zmc_m6] [Failed to prime capture of initial monitor]
Jun 14 10:56:13 zm3 kernel: [ 807.443048] perf: interrupt took too long (2626 > 2500), lowering kernel.perf_event_max_sample_rate to 76000
Jun 14 10:56:21 zm3 zmwatch[1233]: ERR [Memory map file '/dev/shm/zm.mmap.4' does not exist in zmMemAttach. zmc might not be running.]
Jun 14 10:56:23 zm3 zmc_m1[3170]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:56:23 zm3 zmc_m1[3170]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:56:29 zm3 zmc_m4[5979]: ERR [zmc_m4] [Can't mkdir /mnt/mnt126/4: Permission denied]
Jun 14 10:56:35 zm3 zmc_m1[3170]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:56:35 zm3 zmc_m1[3170]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:56:41 zm3 zmc_m4[5979]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:56:48 zm3 zmc_m1[3170]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:56:48 zm3 zmc_m1[3170]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:56:53 zm3 zmc_m4[5979]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:56:53 zm3 zmc_m4[5979]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:57:02 zm3 zmc_m1[3170]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:57:02 zm3 zmc_m1[3170]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:57:02 zm3 zmwatch[1233]: WAR [Restarting capture daemon for Living Room, no image since startup. Startup time was 1655229372 - now 1655229422 > 45]
Jun 14 10:57:03 zm3 PackageKit: daemon quit
Jun 14 10:57:03 zm3 systemd[1]: packagekit.service: Succeeded.
Jun 14 10:57:03 zm3 zmc_m1[3170]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:57:03 zm3 zmc_m1[3170]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:57:06 zm3 zmc_m4[5979]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:57:06 zm3 zmc_m4[5979]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:57:06 zm3 zmc_m1[5996]: ERR [zmc_m1] [Can't mkdir /mnt/mnt126/1: Permission denied]
Jun 14 10:57:09 zm3 systemd[1]: Stopping ZoneMinder CCTV recording and surveillance system...
Jun 14 10:57:12 zm3 zmc_m4[5979]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Interrupted system call]
Jun 14 10:57:12 zm3 zmc_m4[5979]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:57:13 zm3 zmc_m1[5996]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Interrupted system call]
Jun 14 10:57:23 zm3 zmdc[1169]: WAR ['zmfilter.pl --filter_id=2 --daemon' has not stopped at 22/06/14 10:57:23 after 10 seconds. Sending KILL to pid 1227]
Jun 14 10:57:24 zm3 zmdc[1169]: WAR ['zmstats.pl' has not stopped at 22/06/14 10:57:24 after 10 seconds. Sending KILL to pid 1244]
Jun 14 10:57:24 zm3 zmdc[1169]: WAR ['zmwatch.pl' has not stopped at 22/06/14 10:57:24 after 10 seconds. Sending KILL to pid 1233]
Jun 14 10:57:24 zm3 zmdc[1169]: WAR ['zmfilter.pl --filter_id=1 --daemon' has not stopped at 22/06/14 10:57:24 after 10 seconds. Sending KILL to pid 1222]
Jun 14 10:57:26 zm3 systemd[1]: zoneminder.service: Succeeded.
Jun 14 10:57:26 zm3 systemd[1]: Stopped ZoneMinder CCTV recording and surveillance system.
Jun 14 10:57:45 zm3 systemd[1]: Starting ZoneMinder CCTV recording and surveillance system...
Jun 14 10:57:46 zm3 systemd[1]: Starting Cleanup of Temporary Directories...
Jun 14 10:57:46 zm3 systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Jun 14 10:57:46 zm3 systemd[1]: Finished Cleanup of Temporary Directories.
Jun 14 10:57:48 zm3 zmc_m1[6101]: ERR [zmc_m1] [Can't mkdir /mnt/mnt126/1: Permission denied]
Jun 14 10:57:48 zm3 zmc_m4[6106]: ERR [zmc_m4] [Can't mkdir /mnt/mnt126/4: Permission denied]
Jun 14 10:57:51 zm3 systemd[1]: Started ZoneMinder CCTV recording and surveillance system.
Jun 14 10:57:59 zm3 zmc_m1[6101]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:00 zm3 zmc_m4[6106]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:08 zm3 zmc_m4[6106]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: No route to host]
Jun 14 10:58:08 zm3 zmc_m4[6106]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:58:11 zm3 zmc_m1[6101]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:11 zm3 zmc_m1[6101]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:58:15 zm3 kernel: [ 929.026292] 8139too 0000:06:04.0 enp6s4: link up, 100Mbps, full-duplex, lpa 0x45E1
Jun 14 10:58:15 zm3 systemd-networkd[767]: enp6s4: Gained carrier
Jun 14 10:58:21 zm3 zmc_m4[6106]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:21 zm3 zmc_m4[6106]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:58:24 zm3 zmc_m1[6101]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:24 zm3 zmc_m1[6101]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:58:35 zm3 zmc_m4[6106]: ERR [zmc_m4] [Unable to open input rtsp://192.168.25.21:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:35 zm3 zmc_m4[6106]: ERR [zmc_m4] [Failed to prime capture of initial monitor]
Jun 14 10:58:38 zm3 zmc_m1[6101]: ERR [zmc_m1] [Unable to open input rtsp://:@192.168.25.20:554/user=admin_password=tlJwpbo6_channel=0_stream=0.sdp?real_stream due to: Immediate exit requested]
Jun 14 10:58:38 zm3 zmc_m1[6101]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Jun 14 10:58:40 zm3 zmwatch[6121]: WAR [Restarting capture daemon for Living Room, no image since startup. Startup time was 1655229468 - now 1655229520 > 45]
Zoneminder 1.36.17 Freezing on Third Camera
- Log.jpg (129.37 KiB) Viewed 1572 times
Re: Zoneminder 1.36.17 Freezing on Third Camera
Lower the camera resolution. 720P or lower. Lower the frame rate to 10 or lower at the camera. Run mysqltuner to make adjustments to the database settings (innodb_buffer_pool_size may need to be increased).
Permissions?
