Mlapi Setup Guides
kaltertod
Mlapi Setup Guides
Post by kaltertod »
Again I am looking to expand the use of my newly working zmes install. I am wanting to add detection to a remote zm install about 300 miles away that is setup as follows:
Server A (zm server, zmes install with gpu support) -> <-[VPN}-><- Server B (zmserver)
I basically want Server B to be able to utilize the gpu on Server A for object detection and notifications. (I currently use email to sms for notification).
What specifically would need to be installed on server b to make this run as intended?
Any help is greatly appreciated.
tsp84
Re: Mlapi Setup Guides
Post by tsp84 »
You will need ZMES installed on server b but configure it to send remote detection requests to server a. server a would need mlapi setup and configured, you can also setup server a to use remote detection using mlapi on localhost.
I can't remember exactly how to set it up using the stock mlapi and ZMES as I run my own heavily modified apps. You will need to read the mlapi GitHub instructions to get mlapi set up and doing detections on server A and then configure ZMES on both server A and B to send remote detection requests.
kaltertod
Post by kaltertod »
tsp84 wrote: Wed Jun 15, 2022 4:17 am You will need ZMES installed on server b but configure it to send remote detection requests to server a. server a would need mlapi setup and configured, you can also setup server a to use remote detection using mlapi on localhost.
Thank you for the reply. I think that I am going to go a different route and add a gpu to the second server. That leads me to a new conundrum. ZMNinja cannot receive notifications from multiple servers at the same Is there a way that I can email the output image from ZMES on each server so that I still receive notifications from both servers at the same time?
tsp84
Post by tsp84 »
There is a pushover custom push notification script that can be used to send push notifications using the pushover app. Pushover is available for Android and iOS. I would use that instead of the zmninja notifications as you can send notifications from as many servers as you want. I think pushover has a 10,000 limit per month maximum.
Pushover does cost $5 for a lifetime subscription I believe though.
https://github.com/ZoneMinder/zmeventno ... ushover.py
To enable it you edit the zmeventnotification.ini use_api_push option to yes and then edit pushapi_pishover.py to contain your user and app tokens.
