Hi everybody,
I did install Ubuntu 20.04 lts server and followed the installation guide , the Easy Way: Ubuntu 18.04 (Bionic).
in step 5, Configure the Zoneminder Database, i got an error: ERROR 1050 (42801) at line 1091: Table ´Sessions´already exists , after the following commando:
sudo mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql
I don´t want to screw it all up so perhaps anybody knows what´s going wrong here ?
Thanks !
error in step 5 ubuntu installation zoneminder
Re: error in step 5 ubuntu installation zoneminder
ah ! allright....i see....
. Thank you !
Then i will continue the process tomorrow.
mysql -uroot -p -e "grant lock tables,alter,drop,select,insert,update,delete,create,index,alter routine,create routine, trigger,execute on zm.* to 'zmuser'@localhost identified by 'zmpass';"
Is this second step also necessary ?
You could just drop that database and start over. This assumes, however, that the existing zm database isn't something that contains anything that you wish to retain (if you're doing a new install then that would likely be NO).
You probably won’t need that step either. Should all be done.
I prefer this guide when installing zoneminder on ubuntu 20.04 straight forward and works out of the box everytime.
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
thanks everyone for replying.
No luck until now. Had some troubles with a lacking systemctl. etc. So now did start over again with ubuntu server 22.04.
That script looks good but is talking about Mariadb also.
Suppose i need to choose just one of them, wich one would be a better match . Mariadb or Mysql ?
Have a nice day.
Have a nice day.
I roll with MariaDBChris28 wrote: ↑Tue Jun 28, 2022 8:09 pm thanks everyone for replying.
Have a nice day.
I did manage to install Zoneminder, this time on Xubuntu 22.04 and with the script from kaltertod.
Thanks again for this script and everybody for your comments.
Have a nice day.
Have a nice day.
