Page 1 of 1
Zoneminder Timelapse Scripts
Posted: Sun Jun 26, 2022 3:51 pm
by tycon
Firstly, thanks to the community and iconnor for the work on Zoneminder!
I wanted to share a timelapse script I developed a while back. I finally got around to writing up a readme and putting it on Github. It is a little rough around the edges but has been working for me for years. The use case I have is several cameras in 'record' mode which this script archives into a timelapse nightly. This is a sort of low framerate (I am using 1 frame per minute) archiving process which allows me to go back to view footage from any day over the past few years.
I set this up on my Zoneminder 1.36.19 system running Ubuntu 22.04. Installation will vary depending on your system and storage options.
https://github.com/smokedsalmonbagel/zo ... -timelapse
Re: Zoneminder Timelapse Scripts
Posted: Mon Jun 27, 2022 9:48 pm
by iconnor
That's cool. If saving to mp4 we store a snapshot.jpg and an alarm.jpg. You could use those for the case of not saving jpegs. Also you could use use wget to /index.php?view=image&eid=&fid= to pull a single jpeg from the mp4.
Posted: Fri Jul 01, 2022 3:08 pm
by tycon
Great - yea I didn't know about /index.php?view=image&eid=&fid= for jpegs - could be useful.
Also I just learned the way jpegs are stored is "storage schemes" and not having to do with version of Zoneminder. This script assumes the "medium" scheme.
