Hello.
edit: wrong forum must be in 1.37
zm 1.37.16 (but i check updating to the last then revert)
When a alarm is triggered ZM create a X minutes (8m/10m/25m) video for 10seconds video where in case of 8m the first 7:50 minutes i can only see a freeze frame, after that the last 10 works ok the "real video"
https://i.imgur.com/2HOSso2.png
Sometimes ZM create 20 video files (with excessive length) for same event
ex: https://i.imgur.com/dg7Sxf7.png
Sometimes create multiple videos with excessive length except the last one:
ex: https://i.imgur.com/WnvDoxr.png
This behavior seems to happen more on some cameras than others. (i have four)
any idea?
Incorrect video lenghts
Re: Incorrect video lenghts
I guess those are screenshots.
You can put them here directly with the attachments tab below left of the submit button.
