(1.36.21)how can i init database
Posted: Thu Jul 28, 2022 9:30 am
i want to intall zominder 1.36.21 with remoting mysql.
but i do not know how can i init it
$ mysql -u root -p
mysql> CREATE USER 'root'@'[zm server ip or hostname]' IDENTIFIED BY 'password';
mysql> GRANT ALL PRIVILEGES ON *.* TO 'root'@'[zm server ip or hostname]' WITH GRANT OPTION;
$ mysql -h [zm server ip or hostname] -u root -p < /usr/share/zoneminder/db/zm_create.sql
$ scp root@[zm server ip]:/usr/share/zoneminder/db/zm_create.sql ./
$ mysql -u root -p <./zm_create.sql
sql file is in /usr/share/zoneminder/db after install ? i try it.Ralphred wrote: ↑Thu Jul 28, 2022 1:13 pm You basically do it the normal way (redirecting the creation script into the mysql command) but from your DB client machine (your ZM server), or by copying the sql script to the the DB server and redirecting it locally.
For the "do it from the ZM server" way:
The only extra step is to create an 'admin' user for the host you will be connecting from, so from the DB Server machineThen when you run the install script command (or any other mysql command) on the ZM machine add the -h [host] switchCode: Select all
$ mysql -u root -p mysql> CREATE USER 'root'@'[zm server ip or hostname]' IDENTIFIED BY 'password'; mysql> GRANT ALL PRIVILEGES ON *.* TO 'root'@'[zm server ip or hostname]' WITH GRANT OPTION;
For the "do it locally on the DB server" way:Code: Select all
On the DB server, copy the creation script locally and run it from thereFor both methods, when you add the zmuser to the database you have to use the @'[zm server ip or hostname]' instead of @'localhost' and also update the ZM_DB_HOST in your zm.conf.Code: Select all
$ scp root@[zm server ip]:/usr/share/zoneminder/db/zm_create.sql ./ $ mysql -u root -p <./zm_create.sql
It doesn't work. I tried it.Ralphred wrote: ↑Thu Jul 28, 2022 1:13 pm You basically do it the normal way (redirecting the creation script into the mysql command) but from your DB client machine (your ZM server), or by copying the sql script to the the DB server and redirecting it locally.geometry dash bloodbath
