I use Zoneminder on Ubuntu 18.04 from iconnor's repo. Last day I upgraded ZM 1.36.21 to 1.36.23.
My monitors are mjpeg (axis) and some h264.
After upgrade I experienced that there is an message on Monitors:
"Monitor is not capturing. We will be unable to provide an image".
Example I find these in log:
8/6/22, 7:19:06 PM GMT+2 zmc_m2 21523 ERR Failed to capture image from monitor 2 Kamera-2 (1/1) zmc.cpp 306
8/6/22, 7:19:06 PM GMT+2 zmc_m2 21523 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1087
8/6/22, 7:19:06 PM GMT+2 zmdc 1282 INF Starting pending process, zmc -m 1 zmdc.pl -
8/6/22, 7:19:06 PM GMT+2 zmc_m2 21523 ERR Unable to read subheader zm_remote_camera_http.cpp 937
8/6/22, 7:19:06 PM GMT+2 zmc_m2 21523 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 241
8/6/22, 7:19:06 PM GMT+2 zmdc 1282 INF 'zmc -m 2' sending stop to pid 21523 at 22/08/06 19:19:06 zmdc.pl -
8/6/22, 7:19:06 PM GMT+2 zmdc 1282 INF 'zmc -m 1' exited normally zmdc.pl -
8/6/22, 7:19:06 PM GMT+2 zmwatch 1555 INF Restarting capture daemon for Kamera-2, shared data not valid zmwatch.pl -
8/6/22, 7:19:06 PM GMT+2 zmwatch 1555 ERR Shared data size conflict in shared_data for monitor Kamera-2, expected 768, got 760 zmwatch.pl -
8/6/22, 7:19:06 PM GMT+2 zmc_m1 21515 ERR Failed to capture image from monitor 1 Kamera-1 (1/1) zmc.cpp 306
8/6/22, 7:19:06 PM GMT+2 zmc_m1 21515 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1087
8/6/22, 7:19:06 PM GMT+2 zmc_m1 21515 ERR Unable to read subheader zm_remote_camera_http.cpp 937
8/6/22, 7:19:06 PM GMT+2 zmc_m1 21515 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 241
8/6/22, 7:19:06 PM GMT+2 zmdc 1282 INF 'zmc -m 1' sending stop to pid 21515 at 22/08/06 19:19:06 zmdc.pl -
8/6/22, 7:19:06 PM GMT+2 zmc_m1 21515 INF Kamera-1: 50 - Capturing at 5.00 fps, capturing bandwidth 301283bytes/sec Analysing at 5.00 fps zm_monitor.cpp 1681
8/6/22, 7:19:06 PM GMT+2 zmwatch 1555 INF Restarting capture daemon for Kamera-1, shared data not valid zmwatch.pl -
8/6/22, 7:19:06 PM GMT+2 zmwatch 1555 ERR Shared data size conflict in shared_data for monitor Kamera-1, expected 768, got 760
I removed Monitors and recreate them but nothing changed the error is same.
ZM cannot display and record images from any camera.
Can someone help me?
Thanks and Regards
Zoneminder 1.36.23 Monitor is not capturing
Re: Zoneminder 1.36.23 Monitor is not capturing
As per the many similar threads, update to 1.36.24.
@Magic919
Thank you for your advice. I didn't find newer update but I checked it now again and I found 1.36.24. I upgraded it now and it seems to be this version is work.
I think someone experienced same problems and iconnor made a pacth.
Thanks iconnor for quick fix.
Thanks and Regards
Thanks and Regards
