Can someone post the 1.36 update diskspace filter?
zm_user1001
Post by zm_user1001 »
I accidentally nuked the update diskspace filter on my new install. Can someone please post the default settings for that? Thank you.
Andyrh
Re: Can someone post the 1.36 update diskspace filter?
Post by Andyrh »
This is the filter I use.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
zm_user1001
That looks like a modification to the default filter1
The one I nuked was the second filter, I was assuming that was the filter that updated the diskspace filter as it's being utilized. Sorry, I should have been more clear on that.
zm_user1001
To be more precise what I'm trying to solve:
In my console, the amount of space utilized by events is not updating unless I view events. When I search for that issue, I do find older forum threads which reference the filter that should be updating it. Since there are some significant filter changes between versions, I'm assuming that's what the second default filter (filter 2?) did, which is the one I accidentally nuked and cannot find a reference to for 1.36.
zm_user1001
Perfect, thank you.
