SKINS & CSS
DVB Hardware
SKINS & CSS
Post by DVB Hardware »
I have been trying to tweak the UI colors for better contrast for my eyes. A while back when knight worked on the css I was able to tweak the dark mode easily. Seems that much is changed since then that the old css I used has changed much from my new dark mode from an older archive.
Seems as though dark does not have all the css as before but has references to the base now.
I copied classic and named it mod, the problem is when selecting Options - Display setting mod / green_dark the ui goes blank but fine in the classic skin. I don't want to change any anything in classic but only in mod skin
I'm seeing some css references is to the base.
If this is correct Option>System Skin/CSS defaults set the UI colors for any user logging in
Option>Display lets the logged in user change the skin /colors but no access to to change the system skin etc.
DVB Hardware
Re: SKINS & CSS
Figured it out, MOD CSS was 1 folder too deep in the tree
