Page 1 of 1
[Solved] NODECT catching the tail end of the events...
Posted: Sun Aug 21, 2022 11:20 pm
by justanotherguy
Hi all,
I have a setup for my RLC 811a whereby on the sub stream I have set it up on mocord and setup NODECT on the main stream where the substream is setup as a linked monitor. I have 2 zones defined for the substream and I have noticed that quite often, the main stream will record the tail end of the motion event.
I would like to understand how to fine tune so that I can catch the event from the start. Currently, for a lot of events eg. if an object is moving from right to left in the first zone (image 1), the event will be recorded when the object reaches towards the left edge of the zone. This happens for both for vehicles and pedestrians. Any advice how to go about fixing it?
Here are the zone settings for the 2 zones:
Other settings are as follows:
Re: NODECT catching the tail end of the events...
Posted: Sun Aug 21, 2022 11:25 pm
by justanotherguy
...contd
Settings for NODECT (Main stream) are:
Posted: Sun Aug 21, 2022 11:26 pm
by justanotherguy
...contd
Posted: Wed Aug 24, 2022 10:16 pm
by justanotherguy
Since zoneminder's motion detection is a bit finicky, I decided to use the camera's motion detection and populate the event into zoneminder...
Here is how I did it on my RLC 811A. There is an option in the camera to send the motion event to a ftp server. I utilized that feature. Created a script in python to copy the event from ftp folder onto zoneminder. Basically, I now run the high res monitor in NODECT and I have disconnected it from the low res stream and when an event is recorded in the ftp folder, I insert an event record into zoneminder mysql database. The recordid after insert is the event id. Create folder in zoneminder's events folder. Copy the .mp4 file from ftp folder into zoneminder. That's it. Now the event is visible from zoneminder web interface and the motion detection is much more accurate. Another benefit is that now I have sound in the recordings which was not the case when zoneminder was recording the motion events.
Posted: Thu Aug 25, 2022 12:31 am
by Ralphred
justanotherguy wrote: Wed Aug 24, 2022 10:16 pmSetting up edge detection motion recording just to work around a "detection lag bug", AND seamlessly pushing the data back to the NVR
Nice work friend.
