Cannot get ZM 1.36 to work
terence8888
Post by terence8888 »
Hi All,
I'm pretty new to this so please pardon my ignorance. I've just installed ZM on a Ubuntu 22.04 machine. I have gone as far as there are zm processes shown on ps ax. Followed the steps for apache2 but I don't get a nice UI but the webpage as below. Apache is running OK I think (point to localhost/indel.php produced the right result).
Any pointers will be much appreciated.
debugOn() ) { ob_start(); phpinfo(INFO_VARIABLES); ZM\Debug(ob_get_contents()); ob_end_clean(); } global $Servers; $Servers = ZM\Server::find(); if ( (isset($_SERVER['HTTPS']) && $_SERVER['HTTPS'] == 'on') or (isset($_SERVER['HTTP_X_FORWARDED_PROTO']) and ($_SERVER['HTTP_X_FORWARDED_PROTO'] == 'https')) ) { $protocol = 'https'; } else { $protocol = 'http'; } define('ZM_BASE_PROTOCOL', $protocol); // Absolute URL's are unnecessary and break compatibility with reverse proxies // define( "ZM_BASE_URL", $protocol.'://'.$_SERVER['HTTP_HOST'] ); // Use relative URL's instead define('ZM_BASE_URL', ''); require_once('includes/functions.php'); if ( $_SERVER['REQUEST_METHOD'] == 'OPTIONS' ) { ZM\Debug('OPTIONS Method, only doing CORS'); # Add Cross domain access headers CORSHeaders(); return; } if ( isset($_GET['skin']) ) { $skin = $_GET['skin']; } else if ( isset($_COOKIE['zmSkin']) ) { $skin = $_COOKIE['zmSkin']; } else if ( defined('ZM_SKIN_DEFAULT') ) { $skin = ZM_SKIN_DEFAULT; } else { $skin = 'classic'; } if (!is_dir('skins/'.$skin) ) { $skins = array_map('basename', glob('skins/*', GLOB_ONLYDIR)); if ( !in_array($skin, $skins) ) { ZM\Error("Invalid skin '$skin' setting to ".$skins[0]); $skin = $skins[0]; } } global $css; if ( isset($_GET['css']) ) { $css = $_GET['css']; } else if ( isset($_COOKIE['zmCSS']) ) { $css = $_COOKIE['zmCSS']; } else if ( defined('ZM_CSS_DEFAULT') ) { $css = ZM_CSS_DEFAULT; } else { $css = 'classic'; } if (!is_dir("skins/$skin/css/$css")) { $css_skins = array_map('basename', glob('skins/'.$skin.'/css/*', GLOB_ONLYDIR)); if (count($css_skins)) { if (!in_array($css, $css_skins)) { ZM\Error("Invalid skin css '$css' setting to " . $css_skins[0]); $css = $css_skins[0]; } else { $css = ''; } } else { ZM\Error("No css options found at skins/$skin/css"); $css = ''; } } define('ZM_BASE_PATH', dirname($_SERVER['REQUEST_URI'])); define('ZM_SKIN_PATH', "skins/$skin"); define('ZM_SKIN_NAME', $skin); $skinBase = array(); // To allow for inheritance of skins if (!file_exists(ZM_SKIN_PATH)) ZM\Fatal("Invalid skin '$skin'"); $skinBase[] = $skin; zm_session_start(); if ( !isset($_SESSION['skin']) || isset($_REQUEST['skin']) || !isset($_COOKIE['zmSkin']) || ($_COOKIE['zmSkin'] != $skin) ) { $_SESSION['skin'] = $skin; zm_setcookie('zmSkin', $skin); } if ( !isset($_SESSION['css']) || isset($_REQUEST['css']) || !isset($_COOKIE['zmCSS']) || ($_COOKIE['zmCSS'] != $css) ) { $_SESSION['css'] = $css; zm_setcookie('zmCSS', $css); } # Running is global but only do the daemonCheck if it is actually needed $running = null; # Add Cross domain access headers CORSHeaders(); // Check for valid content dirs if ( !is_writable(ZM_DIR_EVENTS) ) { ZM\Warning("Cannot write to event folder ".ZM_DIR_EVENTS.". Check that it exists and is owned by the web account user."); } # Globals $action = null; $error_message = null; $redirect = null; $view = null; $user = null; if ( isset($_REQUEST['view']) ) $view = detaintPath($_REQUEST['view']); $request = null; if ( isset($_REQUEST['request']) ) $request = detaintPath($_REQUEST['request']); require_once('includes/auth.php'); # Only one request can open the session file at a time, so let's close the session here to improve concurrency. # Any file/page that sets session variables must re-open it. session_write_close(); require_once('includes/Storage.php'); require_once('includes/Event.php'); require_once('includes/Group.php'); require_once('includes/Monitor.php'); // lang references $user[Language] so must come after auth require_once('includes/lang.php'); foreach ( getSkinIncludes('skin.php') as $includeFile ) { require_once $includeFile; } if ( isset($_REQUEST['action']) ) $action = detaintPath($_REQUEST['action']); # The only variable we really need to set is action. The others are informal. isset($view) || $view = NULL; isset($request) || $request = NULL; isset($action) || $action = NULL; if ( (!$view and !$request) or ($view == 'console') ) { // Verify the system, php, and mysql timezones all match #if ( ZM_TIMEZONE ) #date_default_timezone_set(ZM_TIMEZONE); check_timezone(); } ZM\Debug("View: $view Request: $request Action: $action User: " . ( isset($user) ? $user['Username'] : 'none' )); if ( ZM_ENABLE_CSRF_MAGIC && ( $action != 'login' ) && ( $view != 'view_video' ) && // only video no html ( $view != 'image' ) && // view=image doesn't return html, just image data. ( $request != 'control' ) && //( $view != 'frames' ) && // big html can overflow ob ( $view != 'archive' ) // returns data && ( (!isset($_SERVER['CONTENT_TYPE']) or ($_SERVER['CONTENT_TYPE'] != 'application/csp-report')) ) ) { require_once('includes/csrf/csrf-magic.php'); #ZM\Debug("Calling csrf_check with the following values: \$request = \"$request\", \$view = \"$view\", \$action = \"$action\""); csrf_check(); } # Need to include actions because it does auth if ( $action and !$request ) { if ( file_exists('includes/actions/'.$view.'.php') ) { ZM\Debug("Including includes/actions/$view.php"); require_once('includes/actions/'.$view.'.php'); } else { ZM\Warning("No includes/actions/$view.php for action $action"); } } # If I put this here, it protects all views and popups, but it has to go after actions.php because actions.php does the actual logging in. if ( ZM_OPT_USE_AUTH and (!isset($user)) and ($view != 'login') and ($view != 'none') ) { if ($request) { # requests only return json header('HTTP/1.1 401 Unauthorized'); exit; } $view = 'none'; $redirect = ZM_BASE_URL.$_SERVER['PHP_SELF'].'?view=login'; zm_session_start(); $_SESSION['postLoginQuery'] = $_SERVER['QUERY_STRING']; session_write_close(); } else if ( ZM_SHOW_PRIVACY && ($view != 'privacy') && ($view != 'options') && (!$request) && canEdit('System') ) { $view = 'none'; $redirect = ZM_BASE_URL.$_SERVER['PHP_SELF'].'?view=privacy'; $request = null; } if ( isset($_REQUEST['redirect']) ) $redirect = '?view='.detaintPath($_REQUEST['redirect']); if ( $redirect ) { ZM\Debug("Redirecting to $redirect"); header('Location: '.$redirect); return; } if ( $request ) { foreach ( getSkinIncludes('ajax/'.$request.'.php', true, true) as $includeFile ) { if ( !file_exists($includeFile) ) ZM\Fatal("Request '$request' does not exist"); require_once $includeFile; } return; } # Add CSP Headers $cspNonce = bin2hex(zm_random_bytes(16)); if ( $includeFiles = getSkinIncludes('views/'.$view.'.php', true, true) ) { ob_start(); CSPHeaders($view, $cspNonce); foreach ( $includeFiles as $includeFile ) { if ( !file_exists($includeFile) ) ZM\Fatal("View '$view' does not exist"); require_once $includeFile; } // If the view overrides $view to 'error', and the user is not logged in, then the // issue is probably resolvable by logging in, so provide the opportunity to do so. // The login view should handle redirecting to the correct location afterward. if ( $view == 'error' && !isset($user) ) { $view = 'login'; foreach ( getSkinIncludes('views/login.php', true, true) as $includeFile ) require_once $includeFile; } while (ob_get_level() > 0) ob_end_flush(); } // If the view is missing or the view still returned error with the user logged in, // then it is not recoverable. if ( !$includeFiles || $view == 'error' ) { foreach ( getSkinIncludes('views/error.php', true, true) as $includeFile ) require_once $includeFile; } ?>
justanotherguy
Re: Cannot get ZM 1.36 to work
Post by justanotherguy »
terence8888
Thanks to both!
I reinstalled multiple times but unfortunately the same result....
Looks like a problem in Apache config, if I’ve understood the problem.
The Zoneminder WIKI has an install script for Ubuntu. Pretty much fool proof. Also I recommend Mariadb server.
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
justanotherguy
Anything else in the error logs?
what's in the folder: /etc/apache2/mods-enabled/ related to php?
lbm
Post by lbm »
From the error there mod-php is not enabled for apache.
smacgre
Post by smacgre »
I have exactly the same script display when I try to use the ZM console web page. It all used to work, and ps -leaf shows lots of zm tasks running as expected. I tried stepping through all the tutorials I can find, to no avail.
Ubuntu 22.04 LTS and zm 1.36.
Any suggestions?
What did you change? Check Apache config, particularly enabled modules, likely PHP is mentioned above.
K1WE
Post by K1WE »
I have the same problem. Is there a solution? where do I go next?
Have you tried the solutions in this thread?
K1WE
Post by K1WE »
I have reinstalled both Lamp and ZM and configured it afterwards but it did not help.
What about the wiki install script? I’d be surprised if it didn’t work.
166MHz
Post by 166MHz »
if I understood correctly, you have outputs php code instead of interpreting the code.
See mod-php apache
need to do something like this
sudo apt install libapache2-mod-php
sudo a2enmod php
sudo systemctl restart apache2
smacgre
Post by smacgre »
I have the same problem: get script text dump instead of zm console run. All used to work, then died after upgrade.
I tried remove/reinstall, followed suggested scripts etc. - no change.
The suggested command
"sudo a2enmod php"
failed:
"ERROR: Module php does not exist!"
Is that significant?
