Hikvision DS-2DE5425IW-AE PTZ Control
iamnotme
Post by iamnotme »
I am looking at using Zoneminder to replace the Hikvision NVR we have. I have the cameras set up and working as monitors, but I can't seem to get PTZ control working on the DS-2DE5425IW-AE.
Has anyone used one of these before and managed to get it working?
Thanks,
Jon
Re: Hikvision DS-2DE5425IW-AE PTZ Control
It works fine on my DS-2DE4A425IW-DE. Underlying protocol will be the same.
iamnotme
Post by iamnotme »
I have checked the logs when pressing the control in ZMNinja and the response from the camera is '302 temporarily moved', which normally happens when it is redirecting http to https. I do have https set on, should that be off?
The annoying thing is the PTZ control worked using Shinobi, which discovered it via ONVIF, albeit very slowly. For some reason ZoneMinder won't find this camera via ONVIF, but it will find the other two I have.
iamnotme
Post by iamnotme »
It does indeed need to be off. It works with https disabled, albeit with tons of lag but I do also have the camera connect to the NVR so that is getting data too.
