Problem in creating USB camera monitor on Zoneminder-master latest 1.37.21~20220901080804-focal[ Solved ]
bkjaya1952
Post by bkjaya1952 »
I have tested the latest Zoneminder master 1.37.21~20220901080804 released today for focal and bionic versions and found the following problems.
1 . 1.37.21~20220901080804-focal on Ubuntu focal - USB monitor cannot be created. error logs are attached below
Screenshot from 2022-09-02 17-56-28.png (409.87 KiB) Viewed 3390 times
2. 1.37.21~20220901080804-bionic on Ubuntu bionic - cannot be installed please see the following figure for the errors
bkjaya1952
Re: Problem in creating USB camera monitor on Zoneminder-master latest 1.37.21~20220901080804-focal[ Solved ]
Sorry I have missed the new feature MQTT .
When MQTT is enabled the problem solved
Now the USB monitor canbe created on Zoneminder master - focal
Thank you very much Sir!
bkjaya1952
Today I have tested 1.37.21~20220907093200-bionic on Ubuntu bionic and found that the problem in installing has been solved.
Thank you very much for solving the issue
