LIVE STREAM New install 1.36.25 ubuntu 22.04
gsaindon
Post by gsaindon »
I just set up a new install. MODECT works fine and I can view the events, but I can't seem to get the live view to work. I only see briefly one image and then nothing. I can't see anything in the logs.
Cameras are configured as pass through. Any idea?
Thanks,
gsaindon
Re: LIVE STREAM New install 1.36.25 ubuntu 22.04
Post by gsaindon »
Here is some precision, the live stream starts after 90sec. Machine is 32 cores 128GB RAM. Weird
What's the video format?
gsaindon
Post by gsaindon »
h264
That should be fine if it's plain H.264.
If you don't see anything in the logs, you'll need to turn them up to debug. Level 3 is usuallyy suggested.
Sounds like cgi-bin scriptalias problem. live view uses zms, event view just plays the mp4.
