Nextiva S1816e Video Encoder
twice
Post by twice »
Good day, long time user
i run ubuntu 18.04 zm 1.36.25
I have a Nextiva S1816e Video Encoder suports rtp/rstp everything works fine in VLC but i get this error
in zoneminder
9/14/22, 11:17:47 PM CDT zms_m17 3444 ERR Unable to connect to monitor id 17 for streaming zm_stream.cpp 60
9/14/22, 11:17:47 PM CDT zms_m17 3444 ERR Can't open memory map file /dev/shm/zm.mmap.17: No such file or directory zm_monitor.cpp 927
9/14/22, 11:17:47 PM CDT zms_m17 3444 ERR Monitor shm is not connected zm_stream.cpp 78
9/14/22, 11:17:47 PM CDT zms_m17 3444 ERR Monitor shm is not connected zm_stream.cpp9/14/22, 11:17:43 PM CDT zmc_m17 3535 WAR PulseAudio server connection failure: Connection refused zm_libvlc_camera.cpp 324
running ffmpeg/libvlc source tab
path: rtsp://192.168.2.120:554/media/16/video/2
method: udp/tcp
Target colorspace: 32 bit color
Capture Resolution (pixels): 720x480 720x480 Full D1 NTSC
Orientation: Normal
Deinterlacing: disabled
any help would be appreciated
edit... when using the libvlc the Nextiva GUI shows 6 connections
Re: Nextiva S1816e Video Encoder
Better to use the ffmpeg monitor type.
We need logs from zmc, not zms. zms is basically complaining that zmc isn't running which isn't terribly informative.
twice
Post by twice »
thanks for reply !
9/15/22, 7:59:14 AM CDT zmc_m17 6631 ERR Unable to open input rtsp://192.168.2.120:554/media/16/video/2 due to: Invalid data found when processing input zm_ffmpeg_camera.cpp 326
dont know exactly whaqt you need but this is zmc
Basically what this message means is that zmc (ffmpeg) wasn't able to figure out the stream in time. This device may have a really large keyframe interval, or something. You can increase Options->System->WATCH_MAX_DELAY or try setting Monitor->Source->OPtions to include probesize=50000 (or larger).
Also if you havn't already done so, try both udp/tcp. Sometimes one or the other isn't implemented.
twice
Post by twice »
thanks ...
i have done tcp/udp will try the above sugestions
have a good day ...
twice
Post by twice »
Good day,
ok firmware updated and zmc has more errors
9/15/22, 6:58:34 PM CDT	zmc_m17		139713	DB2	SDP:v=0o=- 1267021786790565 1 IN IP4 192.168.2.120s=VVS RTSP Servert=0 0a=control:*a=range:npt=0-m=video 0 RTP/AVP 96a=control:/media/16/video/2a=rtpmap:96 H264/90000a=fmtp:96 packetization-mode=1;profile-level-id=4d401f;sprop-parameter-sets=Z01AH+coFg/f+AAoAFiAAAXdgAFfkHAAAAas/AAANWfh//8YAAADA1Z+AAAas/D//4EA,aP48gAA=c=IN IP4 0.0.0.0	zm_ffmpeg.cpp	69
9/15/22, 6:58:30 PM CDT	zmc_m17		139713	DB3	RTP Profile IDC: 4d Profile IOP: 40 Level: 1f	zm_ffmpeg.cpp	69
9/15/22, 6:58:30 PM CDT	zmc_m17		139713	DB3	RTP Packetization Mode: 1	zm_ffmpeg.cpp	69
9/15/22, 6:58:30 PM CDT	zmc_m17		139713	DB3	video codec set to: h264	zm_ffmpeg.cpp	69
9/15/22, 6:58:30 PM CDT	zmc_m17		139713	DB3	Failed to parse interval end specification ''	zm_ffmpeg.cpp	69
and this also but no video
[9/15/22, 6:58:27 PM CDT	zmc_m17		139713	DB2	Successfully connected to 192.168.2.120 port 554	zm_ffmpeg.cpp	69
9/15/22, 6:58:27 PM CDT	zmc_m17		139713	DB2	Starting connection attempt to 192.168.2.120 port 554	zm_ffmpeg.cpp	69
thanks !
Small snippets of logs are not very useful. Post the whole thing, or send it to isaac@zoneminder.com.
twice
Post by twice »
good day,
after alot more research this seems to be a ffmpg issue not zoneminder
i guess my only hope is t see if i can get vlc working in zm.
thanks for you time iconnor! and everything you have done !
have a great day!!
