Montage will only display 6 of 8 cameras
I am running Ubuntu 22.04.1 LTS and Zoneminder 1.36.25. I have 8 cameras working. If I set Zoneminder to 'Cycle', each camera displays correctly. If I go to Montage Review, I can see all 8 camera's images.
However, if I go to 'Montage', I only see 6 camera images. They are all showing live video but the page never finishes loading, no matter how long I wait. Weirdly, it is not always the same six cameras. I have tried Firefox and Chromium. I have tried on the computer running Zoneminder and on a separate computer on the same network.
I have gone to Options/Web and turned on web_compact_montage. It does not seem to make a difference. In Montage, I have tried rows of three and rows of 4 and rows of 5. The extra images are not under any of the other images.
Source is Ffmpeg. Method TCP. Mix of Amcrest and ReoLink cameras. Load around 2-3.
What am I missing? Any suggestions?
Re: Montage will only display 6 of 8 cameras
Yeah, that's a browser limitation.
You need multi-port.
https://medium.com/zmninja/multi-port-s ... 836a336c93
I just posted about this as well and was given the same info. The link above worked perfect and was easy to follow.
Multi-port works.
More easy use firefox and follow https://zoneminder.readthedocs.io/en/1.34.7/faq.html (see section I have several monitors configured but when I load the Montage view in FireFox why can I only see two? or, Why don’t all my cameras display when I use the Montage view in FireFox?)
I have 11 cameras working fine in "Montage" view
If it's just you and you use the same computer all the time, yes.More easy use firefox and
Multiport is a universal solution. Works on any browser AFAIK.
I agree, Doug. For public use it's the solution.
For private use, I decided just to replicate the same Firefox configuration on another PC. Moreover with ZM Ninja (on mobile,...) there is no limitation.
To avoid to do multiple port forwarding on the router...
Thank you for your replies. They solved the problem. I took the easy out and did the Firefox method.
I had been running zmNinja Montage before I gave into my 'new shiny' temptation and moved from a well working Bionic Beaver system to Ubuntu 22.04.1.
I tried setting up ZMninja but kept running into problems. For example, .AppImage files do not run without help: https://itsfoss.com/cant-run-appimage-ubuntu/
After seeing pat2's post, I perserved and got ZM ninja working again and will use that.
On my ASUS it’s just two lines.To avoid to do multiple port forwarding on the router...
YMMV
You can also fix the problem by adding multiple server entries and assigning your monitors to the different servers, so that each server has no more than 5 monitors.
Check out this post: viewtopic.php?p=108940
To summarize 2 are the possible solutions (there is a third one by ncpv).montreal73 wrote: ↑Sun Sep 18, 2022 3:39 pm Thank you for your replies. They solved the problem. I took the easy out and did the Firefox method.
A. firefox tweak, very easy and fast: https://zoneminder.readthedocs.io/en/1. ... in-firefox
To solve follow the instructions below:
enter about:config in the firefox's address bar, go to:
browser.cache.check_doc_frequency change 3 to a 1
browser.cache.disk.enable change True -> False
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
B. multi port server configuration: if you have 3 cameras with the following id: 1, 2, 4 (note the id of camera):
- go in Zoneminder: Option-> Network-> Min_Streaming_Port 30000
- go in /etc/apache2/ports.conf (I hope you are working in https way) and add:
<IfModule ssl_module>
Listen 443
Listen 30001 # this is for my first monitor with ID=1
Listen 30002 # this is for my second monitor with ID=2
# port 30003 is not used
Listen 30004 # this is for my third monitor with ID=4
</IfModule>
- go in in your Virtualhost /etc/apache2/sites-enabled/default-ssl.conf and substitute:
<VirtualHost *:443 *:30001 *:30002 *:30004 *>
instead of
<VirtualHost *:443>
- to go in WAN, add in your router the following portforwarding rule: on my ASUS WAN->Virtual Server/Port Forwarding-> Add Profile:
Service Name HTTPS2
Protocol TCP
External Port 30001:30004 (don't mind if are port forwardind a port 30003 you will not use)
Internal IP Address 192.168.1.208 (or whatever is your LAN IP)
restart the router
sudo apachectl -t (to check if apache configuration is correct)
if ok:
sudo service apache2 restart (restart apache)
sudo service zoneminder restart (restart zm)
If you are in http (I do not reccomend if you are in WAN!):
- go in /etc/apache2/ports.conf and add:
Listen 80
go in in your Virtualhost /etc/apache2/sites-enabled/000-default.conf and substitute:
<VirtualHost *:80 *:30001 *:30002 *:30004 *>
instead of
<VirtualHost *:80>
Service Name HTTP2
Protocol TCP
restart the router
if ok:
