Page 1 of 1
Instruction/recomendations for upgrade from 21.04 to 22.04.1 Ubuntu?
Posted: Tue Sep 27, 2022 5:46 am
by streety111
Is it possible to upgrade Ubuntu from 21.04 to 22.04.1 without consequences or is there something to consider?
Re: Instruction/recomendations for upgrade from 21.04 to 22.04.1 Ubuntu?
Posted: Tue Sep 27, 2022 7:42 am
by Magic919
You are probably on 20.04, not 21.04 which doesn't exist.
There were problems with ZM breaking when people did this. Check the forum here.
I'm staying on 20.04 as it's LTS and still supported.
Posted: Tue Sep 27, 2022 8:01 am
by streety111
Magic919 wrote: ↑Tue Sep 27, 2022 7:42 am
And at the same time, he writes that it is no longer supported, nothing can be updated, as well as downloaded from standard repositories.
Posted: Tue Sep 27, 2022 8:36 am
by Magic919
I see what you mean now. You're not on the LTS version and yes, you'll be unsupported. Sorry, I misunderstood.
Looks like you have to get to 22.04.
There might be some pain, but it's a good chance to learn.
Posted: Tue Sep 27, 2022 8:48 am
by streety111
Magic919 wrote: ↑Tue Sep 27, 2022 8:36 am
Thanks for the feedback.
Posted: Tue Sep 27, 2022 7:27 pm
by Andyrh
Be sure you have a DB backup before you start. Worst case you load a new OS and ZM then restore. If the events remain untouched it should find them and you start where you left off.
