zoneminder1.36.28-focal1 - The log file can't be loaded [Solved]
bkjaya1952
Post by bkjaya1952 »
I have tested zoneminder1.36.28-focal1 with USB monitor today , and found the log file can't be loaded.
The brightness adjustment is can be done in this release with out any problem .( It was not working in the previous ZM version )
GingerDave
Re: zoneminder1.36.28-focal1 - The log file can't be loaded
Post by GingerDave »
Hello
Its discussed on the main .28 thread. copy the log.php content from the git master - this will get it working
Hope this helps
bkjaya1952
Re: zoneminder1.36.28-focal1 - The log file can't be loaded [Solved]
I have tested zoneminder- 1.36.29-focal1 ( latest ) today and found that the above problem in loading the log file has been solved .
Dear Sir
Thank you very much for solving the above issue
Screenshot from 2022-10-14 23-08-40.png (309.68 KiB) Viewed 2425 times
