Page 1 of 1
zoneminder1.36.28-focal1 - The log file can't be loaded [Solved]
Posted: Sun Oct 09, 2022 6:22 am
by bkjaya1952
I have tested zoneminder1.36.28-focal1 with USB monitor today , and found the log file can't be loaded.
The brightness adjustment is can be done in this release with out any problem .( It was not working in the previous ZM version )
- logfile.png (63.58 KiB) Viewed 2502 times
Re: zoneminder1.36.28-focal1 - The log file can't be loaded
Posted: Sun Oct 09, 2022 7:56 am
by GingerDave
Hello
Its discussed on the main .28 thread. copy the log.php content from the git master - this will get it working
Hope this helps
Re: zoneminder1.36.28-focal1 - The log file can't be loaded [Solved]
Posted: Fri Oct 14, 2022 5:49 pm
by bkjaya1952
I have tested zoneminder- 1.36.29-focal1 ( latest ) today and found that the above problem in loading the log file has been solved .
Dear Sir
Thank you very much for solving the above issue
- Screenshot from 2022-10-14 23-08-40.png (309.68 KiB) Viewed 2428 times
