Storage location does not work with "Record"?
kibbling
Post by kibbling »
I want to store the Videos to a different drive /var/usbdrive.
So i added this new location in "Storage" as "ExteranlUSB" with the path /var/usbdrive/zoneminder.
In the Camera settings, under Storage, I select "Stograge Area: ExternalUSB, Save JPEGS: Disabled, Video Writer: Camera Passthrough"
The list of cameras show the Storage: ExternalUSB
But all events still geht stored in "Default"
I Tried deleting and adding cameras - it ist always the same. Sowing "ExternalUSB" everywhere in den GUI, but still writing to Default. And Event lists also show "Storage: Default" in the events.
Any tips why this is not working?
Re: Storage location does not work with "Record"?
You could look at the logs.
Did you set permissions on the usb drive? www-data if you're on Ubuntu.
Check your spelling, too.
kibbling
Post by kibbling »
Yes, it was permissions. Sorry for the dump question.
It's easy to miss stuff.
Good luck getting PurgeWhenFull to work on it.
