1.37.1
Foscam VZ4 - copied Foscam C2 config - On the Console page it shows as a black box with "Unable to stream". Setting up Zone is black also. I can Force an alarm and it records but detection doesn't work.
thanks for any help
No image in Console - mondect works
Re: No image in Console - mondect works
What OS? We're up to 1.37.24 on Ubuntu. It works well for me, although I have no Foscams.
Does it work with VLC?
Correction: mondect NOT working - a Force Alarm does record
Fedora 32
vlc rtsp://fc1:43fce12345@sg68:443/videoMain works great
ZM config:
Source Type: Ffmpeg
Function: Modect
Source: rtsp://fc1:43fce12345@sg68:443/videoMain
Method: TCP
Color: 32 bit
Res: 2304x1536
The thumbnail in column 1 is black with the text "Unable to stream"
However the thumbnail on the Events list is there.
[edit] I keep thinking of more info: 3 other cams are working just fine.
<sigh>
Fedora 32
ZM config:
Source Type: Ffmpeg
Function: Modect
Method: TCP
Color: 32 bit
Res: 2304x1536
<sigh>
I've removed my other cameras and looking at zms_m8.log:
10/12/22 17:29:29.856160 zms_m8[3655622].ERR-zm_monitor.cpp/910 [Can't open memory map file /dev/shm/zm.mmap.8: No such file or directory]
10/12/22 17:29:29.856249 zms_m8[3655622].ERR-zm_stream.cpp/59 [Unable to connect to monitor id 8 for streaming]
10/12/22 17:29:29.856376 zms_m8[3655622].ERR-zms.cpp/268 [Unable set start stream for monitor 8]
10/12/22 17:29:29.136185 zms_m8[3655603].ERR-zm_monitor.cpp/910 [Can't open memory map file /dev/shm/zm.mmap.8: No such file or directory]
10/12/22 17:29:29.136379 zms_m8[3655603].ERR-zm_stream.cpp/59 [Unable to connect to monitor id 8 for streaming]
10/12/22 17:29:30.182861 zms_m8[3655603].ERR-zm_stream.cpp/77 [Monitor shm is not connected]
10/12/22 17:29:30.183060 zms_m8[3655603].ERR-zm_monitor.cpp/910 [Can't open memory map file /dev/shm/zm.mmap.8: No such file or directory]
10/12/22 17:29:30.183111 zms_m8[3655603].ERR-zm_stream.cpp/59 [Unable to connect to monitor id 8 for streaming]
Says /dev/shm/zm.mmap.8 not there, but it is.
You get video with modect forced alarm, or just the alarm shows?
If just the alarm shows, have you tried UDP? If you're compiling, see if there's new source. .1 is pretty ancient and a lot of changes since.
I bring up the black [Unable to stream] window and click on [Force alarm] - then 1001, 1002 -1030 - [Cancel alarm] everything is normal - hr,day,wk shows count, I can click on the number and get a listing of the alarm and the thumbnail on the right and can click on the timestamp and watch the 30 seconds of my deck.
I'm going to (try) to update from 37 to 38?
Master is at 1.36.29I'm going to (try) to update from 37 to 38?
Dev is at 1.37.24
37 will become 1.38. or maybe 2.0 whenever it's released.
Probably won't help with the camera though. I take it UDP didn't help?
NEVER MIND
I got the wild hair to reload another machine with ZM - and @&$%&!%&%$*!!! IT WORKS just fine.
