Error while saving video
superdipak
Post by superdipak »
I have been using Zoneminder for years without issues. This morning, ever since I upgraded to 1.36.5, I have been seeing an error in the logs every time the system tries to save a video at the end of a recording interval (currently set to 300 secs). The error message I see is as follows:
Error writing trailer Error number 333 occurred
The number (33) shown above is different for each of the 6 cameras I have. This error occurs only once every 5 minutes when the video is saved.
The camera's have been configured as follows:
Source type: ffmpeg
Function Mocord
Source path: rtsp://<IP>:<port>/stream0
Method: TCP
Video writer: camera passthrough
I have played with several options including encoding for the video writer but the issue refused to go away.
Can anyone help? Any thoughts would be most appreciated.
Regards
Dipak Jha
Re: Error while saving video
You must upgrade to the latest. 1.36.29. This issue was fixed a long time ago.
superdipak
Thanks iconnor. Once again, you have bailed me out. 1.36.29 works like a charm :D
